ground problem |
Post Reply
| Author | |
fordpower
Joined: 02-September-2010 Location: willseyville,ny Status: Offline Points: 1807 |
Quote Reply
Topic: ground problemPosted: 15-February-2020 at 2:46AM |
Went to start ltd2 before removing bat, that I had forgot to remove. Small ground wire from bat melted in half. Wondered why it was smoking under hood, wire totally melted away?
Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14723 |
Quote Reply
Posted: 15-February-2020 at 5:06AM |
sounds like your not getting a good connection somewhere causing it to pull more amps through that small wire???
fordpower
Quote Reply
Posted: 15-February-2020 at 5:33AM |
Ya it has had a grounding problem back in 2014.replaced bat ground cable with one that had a small ground wire that they connected to the fire wall,cleaned all other grounds, problem was fixed. Wait till spring.
Quote Reply
Posted: 15-February-2020 at 5:58AM |
car needs a new neg bat cable or it has a severe bad connection just because the existing cable is somewhat recent doesn't mean it good, economy cable terminals that are stamped or crimped will hide corrosion inside. even from new sitting on the shelf when you buy it. if the connection isn't too corroded badly when you get it home new, you can sweat the crimp. flood with acid and fill with solder
fordpower
Quote Reply
Posted: 15-February-2020 at 9:19AM |
Thanks
Quote Reply
Posted: 15-February-2020 at 9:32AM |
check the ground strap from the back of the engine to the firewall... or make sure you have one from the block to the frame and frame to body. i made a couple heavy ga. ones under the car out of sight
fordpower
Quote Reply
Posted: 16-February-2020 at 12:36PM |
come spring we will go over all grounds like I did after ky. in 2014.
Post Reply
| Tweet |
