  New Posts New Posts RSS Feed - Header Help
Header Help
Jbuss22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jbuss22 Quote  Post ReplyReply Direct Link To This Post Topic: Header Help
    Posted: 09-July-2019 at 6:32AM
Need some Header help - 1971 GT
1) 351 car converted to 429 with Hooker Super Competition Ceramic Headers. Problem with this set up = on the passenger side, one of the pipes based on the way they are configured, hangs down 2-3" lower than all the other pipes. Lower than all the pipes on the drivers side too. So, when i even let off the gas and/or brake, that pipe on passenger side drags on the ground and is already squared off. I order 429 shorty headers but the cross member and engine mounts are in the way for that install to take place.
I'm already at a frustration point - looks like 429 Race headers are a bit more snug but there height/clearance to the ground doesn't look much improved over what i have!
Thoughts - 1) we have already installed 2" front spring lifts to even get it on a trailer to get home when purchase. 2) Are there a set of headers that plug and play with this configuration that you can show me work? Console, PS, PB add to my issues. 3) should I just buy some stock exhaust manifolds for this as an easy and tucked solution?
Thanks all in advance for the input!
JB
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2019 at 12:51PM
You should try FPA headers:
They list a shorty header for 429-460 engines that might work.  It only shows on the Mustang page, but it should fit a 1970-71 Torino too since they are very similar chassis.  Most headers list that they fit 65-73 Mustang and 66-71 Fairlane/Tornio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2019 at 1:40PM
i agree with vince... shorty headers will get the pipe up higher not sure if JBA makes any for 429's???? but i have their 351W set on my torino and work great
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2019 at 2:54PM
Did you do the conversion to 429?
Is the engine sitting level from left to right?
The 67-73 Mustang, 66-71 Torino/Fairlane and 66-69 Falcon are all variations on the same chassis.
Engines sit at different angles/heights in different models and years based on mounts and associated bracketry. And those parts will bolt up in different chassis than they came in.
Mix-and-match parts cause odd problems.
mtburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2019 at 4:09AM
Hello All.
I actually just purchased the FPA 429-460 69-70 Mustang swap headers for a 69 Montego I just got.
Speaking to Stan, he said they fit perfect, and guaranties there to be no fitment or ground clearance issues.
With shipping and the CeramaChrome coating, they cost $1099.00.
What can I say, it's not 1974 anymore...
Mike H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jbuss22 Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2019 at 11:15AM
Thanks again for this  - calling them first thing Monday. this might just be it!!
JB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jbuss22 Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2019 at 10:12AM
Does anyone have a working phone number for them? I’m trying the one on the site and it dies after one ring
JB
Post Options Post Options   Thanks (0) Thanks(0)   Quote mtburger Quote  Post ReplyReply Direct Link To This Post Posted: 26-July-2019 at 12:41PM
I used the phone number on the site, and I have been exchanging email with them. I think they are just pretty busy.
My new headers showed up today, looking at my email, the order confirmation was on 5/15, and he said it was a 6-8 week lead time, and it was about 9 weeks.
Nice stuff, totally worth it.
I didn't post a picture, but my name (all customers names) are stamped in the flange on both headers.
Mike H.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 26-July-2019 at 2:40PM
Shocked FPA is here in washington???? that's about an hour away from me Thumbs Up
