  New Posts New Posts RSS Feed - Headers for 1976 Ranchero 460
rancheromac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Topic: Headers for 1976 Ranchero 460
    Posted: 27-June-2018 at 3:46AM
what header for a 76 460 ranchero ? aquartlow is using hooker 6126, but they are $800.00
Post Options Post Options   Thanks (1) Thanks(1)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 27-June-2018 at 9:02AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2018 at 3:20AM
I put an offer on ! can you tell what outer finish is on these ? thanks again for info
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2018 at 2:15AM
thanks for lead ! I just got them for $300, can you make out what the spray on coating is ? high temp paint or ceramic ?
Post Options Post Options   Thanks (1) Thanks(1)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2018 at 6:38AM
I had my set of headers aluminized. like they do exhaust tubing, held up OK but did start to show slight rust marks. I took them off, had them bead blasted then I sprayed them with VHT high heat/exhaust paint and believe it or not the VHT has faired much better than the aluminized coating(maybe the prep work prior to aluminized coating wasn't good). If mine come off again I want to send them out to be Nitroplated, Jet Hott coated or something similar, will help with under hood temps as well.
