Headers for 1976 Ranchero 460 |
rancheromac ![]() Member ![]() Joined: 12-August-2013 Location: IOWA Status: Offline Points: 57 |
![]() ![]() ![]() ![]() ![]() Posted: 27-June-2018 at 3:46AM |
what header for a 76 460 ranchero ? aquartlow is using hooker 6126, but they are $800.00
aquartlow ![]() Senior Member ![]() ![]() Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2032 |
Make sure you write down all those fuqin' numbers and symbols correctly
![]() Edited by aquartlow - 27-June-2018 at 9:05AM |
I put an offer on ! can you tell what outer finish is on these ? thanks again for info
thanks for lead ! I just got them for $300, can you make out what the spray on coating is ? high temp paint or ceramic ?
I had my set of headers aluminized. like they do exhaust tubing, held up OK but did start to show slight rust marks. I took them off, had them bead blasted then I sprayed them with VHT high heat/exhaust paint and believe it or not the VHT has faired much better than the aluminized coating(maybe the prep work prior to aluminized coating wasn't good). If mine come off again I want to send them out to be Nitroplated, Jet Hott coated or something similar, will help with under hood temps as well.
Tweet
