  New Posts New Posts RSS Feed - Headers for 351M/400
kychevyguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kychevyguy Quote  Post ReplyReply Direct Link To This Post Topic: Headers for 351M/400
    Posted: 29-September-2021 at 12:31AM
I think I am wanting to add some headers to my 76 Ranchero. What has everyone been using? Hookers 6125HKR are the only ones that keep popping up....
JT, USAF Ret./Architect
1971 Ford F100 "Lizzy"
1971 Cougar XR7 "Kitty"
1984 Chevy Silverado "Sylvia"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2021 at 1:11PM
I used Hooker Super Comp 6125s on my 400.  They are the only ones that will fit a 351M or 400 that are still in production.  The right side fits like a glove, very easy to get in.  The left side is tight.  I lifted the engine and also had to clearance a bit around the steering box to get it in.
I "think" Sanderson shorties might work too, but didn't have the guts to try them out.
Edited by 72FordGTS - 02-October-2021 at 2:57PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2021 at 2:07PM
    I had hoped to get headers once I swap my C6 out for a stick. It is probably a pipe dream at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2021 at 3:00PM
I actually just went down that rabbit hole of a manual swap on my car.  Would love a TKX, but it would be a ton of cash.  Have to swap to hydroboost, expensive Big Block Bell housing, expensive hydro clutch which would require a bunch of fab work.  I want an OD trans someday, but I think a Gear Vendors is the most viable option...I'd just rather row my own gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2021 at 2:11PM
  I believe Rick went with a gear vendors OD on his car. If I can't get the complete bell/clutch setup for the 400, I may just build the CJ in the parts car. Time($) will tell.
