  New Posts New Posts RSS Feed - Headlight Question 72 Torino
GT72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT72 Quote  Post ReplyReply Direct Link To This Post Topic: Headlight Question 72 Torino
    Posted: 04-April-2013 at 7:56AM
Hello,
I need your help. It´s about a 1972 Gran Torino.
Could anybody tell me how much watt the headlamps (sealed beam) original have?
What´s correct? Is it correct that all four headlamps burn if I pull the light switch or is it correct that only two headlamps burn while I drive and the other two are only high-beam headlights?
Thank you very much.
Greetings
Dirk
Please excuse my bad english.
GTS73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTS73 Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2013 at 8:43AM
Not sure about wattage off the top of my head, but only the outer lights are lit for low beams. The center lights are active for high beams.
Edited by GTS73 - 04-April-2013 at 8:44AM
-Keith
`04 Wrangler Sport
`73 Gran Torino - sold :(
`68 Torino GT Fastback
GT72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT72 Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2013 at 8:57AM
Hi Keith,
thank you for your answer. I already imagined that only the external(outer) lamps should burn, but I wasn´t sure. On my Torino all four lamps burnt. Now none of them works. ;-)
Greetings
Dirk
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2013 at 10:26AM
Check your dimmer switch and wiring. I have had them go bad - first I could click for normal low/high use, then it was all 4 lights or nothing, then finally it was nothing. No matter how many times I tapped it.
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2013 at 1:00PM
Lights are on a metal auto resetting circuit breaker in the fusebox could check that is plugged in tight.
outer 2 for low beams and all 4 for high is normal. Wattage varies by brand but low 35 t0 40watt high 50 to 60
GT72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT72 Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2013 at 9:25PM
...great forum. thank you all for your help.
because the complete current of all four headlamps go through the light switch, the "thermal-fuse" of the light switch activated and the lights goes out.
now, I will wiring the lamps like original.
If someone is interested in the wiring diagram, here is the link. A member of the german torino forum send it to me:
Many greetings over the pond
dirk
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 4:47AM
wait... theres a german torino forum?
GT72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT72 Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 8:51AM
yes...we´ve got a website with a forum, both hosted and created by an enthusiastic torino driver from bavaria:
http://www.ford-torino.de/torino.htm
there are not a lot torino drivers in germany, but they are unique. Wink
prost Beer
dirk
(here it is 9:50 p.m.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote legend onirot Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 9:13AM
that is cool.   that is awesome!!!
same as here, this is all scotts creation...  an enthusiast.
extra interesting to me because my family came to america from germany and poland in the late 1800's.  thanks for sharing
iangj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iangj Quote  Post ReplyReply Direct Link To This Post Posted: 05-April-2013 at 9:44AM
The resettable circuit breaker is built into the headlight switch.
If using a light of any higher wattage then the original standard incandesant bulb, the increased current draw will cause the breaker to trip then reset when it cools down and this cycle will continue. Eventually the breaker in the switch will become more sensitive and trip even sooner.
Best way is to install relays into the high beam circuit ( and possibly the low beams if using higher wattage lows) to stop this from happening.
Ian Glyn-Jones
Fonthill, Ontario, Canada
Montego GT Registry
GT72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT72 Quote  Post ReplyReply Direct Link To This Post Posted: 06-April-2013 at 3:22AM
hi ian,
you are right. When I fix it, I will install a relais.
hi malcolm,
many americans have their roots in germany or poland. a lot of germans saw the chance for a better living in the new continent.
and a few german words found their way to the american speech.  not all have a positiv connotation and came from germanys darkest years like Blitzkrieg, Panzer, Führer...
this is not my list. It´s an excerpt of a german magazin. I´m not sure if it´s true and so many words are known in the united states.
alpenglow gemuetlich Oktoberfest
angst geist Ostpolitik
Anschluss Gesundheit! (nach Niesen) panzer
autobahn glitz, glitzy pils, pilsner
automat glockenspiel pinscher
bildungsroman hamburger plattenbau
beergarden hamster pretzel (von Brezel)
blitz hausfrau polka
Blitzkrieg Herrenvolk pumpernickel
bratwurst hinterland Reich
coffee-klatsch / klatch howitzer (von Haubitze) reinheitsgebot
concertmeister kaputt rottweiler
dachshund kindergarten rollmops
das ist gut kitsch rucksack
delicatessen, deli knackwurst sauerkraut, sourkraut
diener, deaner kraut (the krauts = die Deutschen) schnapps
Diesel kriegspiel schnauzer (Hunderasse)
dirndl Kristallnacht schnitzel
doberman pinscher lager beer, lager spritz, spritzer
doppelganger leberwurst, liverwurst strudel
dreck, drek Lebensraum U-boat
dummkopf lebkuchen umlaut
edelweiss lederhosen waldmeister
fahrvergnuegen leitmotiv waldsterben
Fest (z.B. beer fest) lied weltschmerz
frankfurter muesli wunderkind
fraulein, frollein Nazi wurst
Führer Neanderthaler zeitgeist
gasthaus
ps: the mother of my grandmother came from poland too.
have a nice weekend
dirk
Edited by GT72 - 06-April-2013 at 3:27AM
