Heater Box Seals for 1972 |
texanrebel
Senior Member Joined: 13-June-2018 Location: Houston, Texas Status: Offline Points: 208 |
Posted: 20-January-2020 at 11:28PM |
Need to replace mine off of the 72 MGT and have not been able to track any down. Anyone know if the seal kit from the 71 Torino will work? Failed heater core dumping antifreeze and 48 years of deterioration did a number on the originals.
Thanks!
1972 Montego GT
1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe |
Admin Group GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 5849 |
I am not sure, but I doubt they would interchange exactly. Little interchanges between a 1971 and 1972. You may be able to modify the 1971 seals to work for your car.
texanrebel
That’s what I guessed, I did order the seal kit from Detroit Muscle Technology anyway as it was reasonably priced. Hopefully I can make most of it work.
1972 Montego GT
Let us know if it works, and post pics if you can make it work.
russosborne
Do you have heater only or is this a heat/ac car? Thanks, Russ
texanrebel
It's a heater only, I will take pictures to compare the 1971 seal kit with what I have and document any modifications I have to make
1972 Montego GT
