  New Posts New Posts RSS Feed - Heater Hose Routing
Heater Hose Routing
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Topic: Heater Hose Routing
    Posted: 05-March-2017 at 1:45AM
Replaced heater hoses and heater control valve recently. Out of curiosity, I googled pics and also looked at several engine bays on several FB sites. In regards to inlet/outlet routing, it seems there is no logical pattern to running them on 351C motors. Some have them going from the water pump to the left side of the heater core, some have them coming out of the block and into the left side of the heater core, and then there is every combination after that. Seems like there's no hard and fast rule, other then if you want heat faster, have the inlet come out of the water pump? But which is the inlet and which is the outlet on a heater core...or does it matter? How did it come out of the factory?
Raises more questions then answers. Shoulda never looked on the internet to begin with!
Matt
1972 Montego MX
2003 Mercury Marauder 300A
2015 Honda Civic Coupe
2016 Ford Fusion Titanium
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2017 at 3:53AM
It doesn't matter which of the tube on the heater core your inlet and outlet go to, it's not flow directional.
However, you should have your heater control valve on the inlet hose going to the heater core.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2017 at 4:07AM
doesn't matter
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 08-March-2017 at 1:40AM
Cool. So the inlet hose should be coming from the water pump....
Matt
1972 Montego MX
