HEI distributor? |
Power Surge
Posted: 23-December-2016 at 10:14AM |
Is anybody running an HEI distributor in a 351m or 400? I'm about to put one in the Ranchero and I'm wondering if it's going to clear the factory air conditioning. I'm guessing I'll probably have to do away with the steel fuel line from the pump to the carburetor as well. Any input would be appreciated.
Sal Mennella
lots of other options that don't need a total rework, what air cleaner are you using? those things are so big they interfere with almost everything
you can use a parts counter duraspark electronic dizzy and wire it up to the same GM 4 pin module that the HEI dizzy uses
Power Surge
I know there are other options. I already have the HEI. $100 for the complete unit PLUS a set of wires was pretty hard to beat. Just can't find any links online to an HEI install on one of these motors that still has the AC.
Sal Mennella
mtburger
Senior Member Joined: 24-November-2008 Location: Abington, MA Status: Offline Points: 355 |
newmexguy
Member Joined: 27-September-2012 Location: las Cruces Status: Offline Points: 163 |
Davis Unified Ignition, most likely.
