  New Posts New Posts RSS Feed - Hi all! Introduction and question...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2017 at 10:46AM
HaHa i'll use pop's old Black & Decker with the brushes blowing flames out the sides LOL
i figure using a hub-centric wheel and a transfer punch one at a time will locate them as good as anything,
tired of paying people (local) to screw it up for me
and it's an excuse to get the drill press up & running, i'll probably drill the discs too
sometimes ya gotta pee with the Censored ya got Shocked
come to think of it this guy's just a yodel or 2 north of you in BC, check him out!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2017 at 1:33PM
After poking around on the interwebs at galaxie swaps, it seems that the 71-72 fullsize rotor will install on the small bearing 72 spindle, but the rotor face is almost 3/8" further outboard.
Later 72-79 intermediate, 73-78 fullsize "partsbin" setup pushes the rotor further inboard on the hub to allow caliper clearance on the small rotor and 14" wheels.
Nobody local has rotors for 72 Thunderbird/Mark IV, pretty much an obsolete part. I doubt Ford/Lincoln made 50,000 Tbirds/Marks in 72 combined, so probably minimal demand for rotors at this time.
Another scary thought, Granada rotors apparently fit the small bearing spindles but also misalign the rotor surface. Small 11" rotor though.
russosborne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote russosborne Quote  Post ReplyReply Direct Link To This Post Posted: 04-November-2017 at 3:49PM
Kanter lists the 72 Tbird/Mk IV rotors on this page
https://www.kanter.com/productdetail.aspx?DeptNo=1100&MakeName=Ford&MakeYear=1972&CategoryID=6&ProductCode=35&Router=Catalog
You have to scroll down a fair bit.
I'm hoping this listing is for real, or else my plans for the 12 inch brake swap will have to make a major change.
Russ
Brake Drum or Rotor 1972-1972 Ford Thunderbird
Front disc
04016R BD 6028 $123.00
per each
Edited by russosborne - 04-November-2017 at 3:50PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-November-2017 at 1:30PM
Originally posted by 72LincolnAbe 72LincolnAbe wrote:
It's almost as if the surface part of the rotor (where the pads contact) needs to be moved in about a quarter of an inch.
Based on what the OP is saying and what Randy is saying, it sounds like the one side of the car may have a 71-72 Fullsize Rotor.
72LincolnAbe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 1:03AM
Well, when we got the car back, it had a completely wrong one on the left front, the bolt pattern was correct, but had to find a junk newer wheel and tire to fit over the hub. No idea what that was from
Edited by 72LincolnAbe - 06-November-2017 at 1:08AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 1:16AM
Wow! Lots of responses! Thanks so much! What Big Bird said is absolutely what the problem is, and I believe the 6014 rotors are what we were sold, the full size stuff for later cars. I'm curious if any of you have a used one for sale? I still have one that can be cut, lots of meat on it. I'm kinda getting tired of beating my head on the desk trying to find a good one. I'm paypal ready if someone has one with life left in it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 2:33AM
there is a place in florida that sells used parts lincoln only i don't recall the name. i ran across them searching for mark 4 disc brakes on the internet
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 3:07AM
If you come across it again, let me know!
qcode72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote qcode72 Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 3:12AM
Lincoln land Clearwater fl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 4:14AM
I did see them before, seemed a little pricey... :/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 7:28AM
like i said Frank thinks he has a pair, i didn't get to what he wants for them because used rotors across the continent  ... IDK ...
Mark IV Designs
18253 N. 42nd Place
Phoenix, Arizona 85032
602-992-6699
between the asking price & consumer shipping i'll bet you can get a new one for not much more
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 8:49AM
Mark IV Designs
18253 N. 42nd Place
602-992-6699
I sure wish I could get my hands on a new one! That right there is my biggest problem Unhappy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 10:11AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2017 at 5:00PM
that's it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2017 at 2:18AM
Ok, I called Lincoln land, they are going to call me back, so fingers crossed. That Kanter place showed one online, but when I called to check availability, the price about doubled for some reason.....
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2017 at 10:13PM
There is a car like yours for sale with no engine for $650.00. The seller needs to get it off his property as soon as possible. I will take a guess and say that if he cannot sell the car soon it is probably going to go to a scrap yard. Maybe you can call him and ask him about the condition of the front rotors and then purchase the rotor from him or the scrap yard. Some scrap yards will sell the rotor for only $20.00 or $30.00. I do not know the seller and I did not talk to him.
Edited by dave302 - 08-November-2017 at 8:04AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2017 at 2:23AM
Thanks! I did get a rotor coming from a place in Cleveland, it was a bit rusty, but my guy thinks it's salvageable. I'd have loved to grab a parts car, but being in Michigan, would have cost an arm and leg to get it here
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2017 at 3:25AM
So! An update of sorts....   The rotor I got did clean up well enough to use, still way over spec on thickness, and worked like a charm. But! Always a but, right? The rotor we thought was right for the car, sadly, is not. It's far closer than the wrong pair I had, but the dust cap that was on it was rotten, and now we are having trouble finding one to properly fit. We got a cap that was a hair to small, welded a small bead around it, and ground it down to fit tight, so I think we're ok there. Grease seal on the back seems to be a little tight on the spindle shaft, but if noting else, it'll wear itself down to close enough.
I really thank you all for the help, and with maybe just a little luck, I can find one more rotor.
On a side note, I don't think I've ever ran across such a situation that so many rotors would "fit" but not be right. I know GM was a little forgiving on swap and cross vehicle swap, but they had issues too.
Time to find another rotor.... Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 13-November-2017 at 10:47AM
Easy answer would be to swap to a 74-79 spindle and get a fullsize73-78 rotor drilled to the correct pattern. Probably cheaper and yield a better result that tracking down a user, very limited production rotor, having it turned.
If I were in the same spot, I might consider getting newer spindles/rotors, a 73-76 drum brake rear, and the wheels that go along with them. If you are running hubcaps, it's an invisible swap.
As far as G.M. goes, try finding rotors for a 78 Malibu or Monte Carlo or any of the other 78 A bodies. Another "one year only" special.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72LincolnAbe Quote  Post ReplyReply Direct Link To This Post Posted: 14-November-2017 at 9:37AM
Agree there! I have an 86 Cutlass and I hear stories about them 78 cars alot!
