  New Posts New Posts RSS Feed - Hood Scoop Template
Hood Scoop Template
piper62j View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Topic: Hood Scoop Template
    Posted: 06-July-2019 at 1:41AM
Does anyone have, or know how to obtain a template for the non functional hood scoop for the 68 - 69 Torinos?  If that's not available, are there dimensions that can be used instead? I just picked up a complete OEM unit with lights and would like to install it on my 68.
Thanks in advance..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2019 at 11:56AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2019 at 1:55PM
 that would probably work for non functional just don't cut out the 4 ovals Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2019 at 3:20PM
the 68-69 scoop is non-functional anyway, even with the holes cut out.  I have  saved the center section of my old scooped hood so I can trace the actual holes for you.  Send me a private message to remind me as I am away from home for a week.
Dave Fox
Post Options Post Options   Thanks (0) Thanks(0)   Quote piper62j Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2019 at 2:50AM
I believe I have found the correct template for this application. The seller does not indicate the vehicle type, but the template is a perfect match for my oem non functional scoop.. Purchased it and will update you on how things work out..
