Forum Home Forum Home > General Discussion > How-To Articles
  New Posts New Posts RSS Feed - How to rebuild rear sway bar links
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-August-2017 at 5:35PM
these are the energy suspension shock bushings i used to replace the rubber ones in the end of the factory rear sway bar  9-8141R (red)   9-8141G (black)
Energy Suspension Shock Bushing 9-8141R
Edited by californiajohnny - 03-August-2017 at 5:37PM
74 CORVETTE COUPE CUSTOM
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2017 at 2:24AM
Thanks man, so just these 2 sets of bushins and its good to go. Thumbs Up
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2017 at 2:55AM
THAT'S IT Thumbs Up
[IMG]TO BE RELOADED[IMG]
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2017 at 12:34PM
I'll have to cross reference them over to the PST stuff, but that shouldn't be a problem. I like the idea of the graphite in there to help stop the squeaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-August-2017 at 3:07PM
they have a grease for them poly bushings! IIRC the PST poly bushing are really hard, i've seen other off brands of hard poly crack and split Shocked never any issues with energy suspension or prothane!!!
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2017 at 1:41PM
Can someone tell me how long that sway bar link is from the top of the spacer to the bottom of the bracket part by the sway bar. I need to make a set of these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 09-August-2017 at 10:28PM
Part numbers, sizes quantity and supplier is listed at the beginning of the thread so it should be pretty easy to figure out....
torino75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino75 Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 3:48AM
Hi,
i am looking to change the bushings for my rear sway bar as well, but before i order the
98141G and 98101G, i am looking for the other set of bushing, those that bolts on the rear axle, but can't find an exact replacement ?? anyone have come up with a bolt-on energy suspension part # ?
I have a stock rear sway bar. Btw, nice write-up  and thnx for those part numbers!!!
Syl
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 5:35AM
Originally posted by torino75 torino75 wrote:
Hi,
Syl
i went with prothane for those bushings because they fit the bar and mounts better these fit the early rear swaybar mounts (some of the later cars have wide mounting bolts)
prothane # 19-1116 BL
Prothane 19-1116-BL SWAY BAR BUSH 17MM FITS A&quot; BRKT
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino75 Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 9:42AM
Hi, thank you for this! I have a 1975 , guess this means it's the later model? (the wider one?) Ill see on the prothane site if they give the specs and then take measure on mine to see if it will fit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 12:01PM
look at the mounts on the axle... mine are a flat strap style the later ones i've seen are like a u-bolt style similar to a muffler clamp?
 but the bar measures 17mm! they refer to it as 5/8" but thats too loose Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino75 Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 1:38PM
Hi,
It's late and all, but i took my flashlight and took these 2 pics. Do these help any ??
Syl
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 2:57PM
I haven't even crawled under to look at the rear sway bar setup on my cars lol  There are 3 sets of bushins involved in the factory setup??!!  Thats crazy, my 73-77 gm a bodies rear sway bar bolted right to the lower control arm, no bushins at all. Wonder which one is the better design?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-August-2017 at 6:10PM
ed, those are the strap style.. so the above part # will work for you!
bob, yeah my vega has the bar bolted to the lower arms, IIRC the chevelles were too
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino75 Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2017 at 12:29AM
Californiajohnny,
thank you for helping out with this, going to order the bushings!
Have a nice day!
Syl
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 14-August-2017 at 4:25AM
Honestly I think the GM bars were more effective. They were directly acted on by the control arms. Causing them to twist and do their thing. Ours aren't as positive of a mount to the control arms leaving some slop in the system.
Edited by yellowsportwagon - 14-August-2017 at 4:28AM
