  New Posts New Posts RSS Feed - idler arm bolts
idler arm bolts
1973gts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Topic: idler arm bolts
    Posted: 02-April-2019 at 8:58AM
Need some help asap. Putting my steering linkage back on and have misplaced my idler arm to frame bolts, can anyone help me with proper size of bolts?  Thanks in advance  -  dave
Dave - 1973 GTS N code
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2019 at 9:47AM
what size are the holes in the frame and idler arm?
how wide is the frame and how thick is the idler?
add 1" and use grade 8 with hardened washers to be safe
Edited by Rockatansky - 02-April-2019 at 9:51AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 02-April-2019 at 1:10PM
Thanks, Rock, sometimes I tend to overthink these things, your advice makes sense, appreciate it.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 3:07AM
I believe that the bolt thread size that you need is 3/8-14 national coarse thread, grade 8 nuts, bolts and washers. The torque specification for the idler arm to frame bolt's are 35 to 50 foot pounds (when you use the 3/8-14 nuts and bolts). This is the torque specs when no lubrication is used (dry).
There is also a possibility that the nut and bolt thread count is supposed to be 3/8-24 national fine thread grade 8. Maybe one of the other members will know if the threads are supposed to be coarse or fine threads. The 3/8-24 nuts and bolts use the same torque specs.
Edited by dave302 - 03-April-2019 at 10:43PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 3:19AM
I will take a guess and say that the frame thickness might be 1/8" to 3/16". The idler arm bracket thickness might be 1/2" to 9/16" thick. And the two washers and the nut thickness might be 1/2" to 9/16" total. So you might need bolts that are at least one and a 1/4 inch long to one and 3/8 inches long, not including the hex head of the bolts.
Edited by dave302 - 03-April-2019 at 3:35AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 3:24AM
Edited by dave302 - 03-April-2019 at 3:28AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 3:33AM
The torque specification for the idler arm to center link nut is 50 to 70 foot pounds. This is the specs with no lubrication used (dry). The procedure to tighten the nut is: Tighten the nut to a minimum of 50 foot pounds and try to install the cotter pin. If the cotter pin does not go in then slowly tighten the nut until you are able to install the cotter pin.
Edited by dave302 - 03-April-2019 at 9:04AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 12:15PM
My fenders are off, so I measured the bolt diameter at 1/2".  There is only maybe a 1/4" of thread beyond the nut once tightened.  Also note, it has the locking style nuts, with the oval opening.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 12:54PM
distorted thread lock nuts Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1973gts Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2019 at 3:59PM
OK, thanks everyone,should be all set
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2019 at 6:00AM
so what size are they for the next time?
