  New Posts New Posts RSS Feed - INFO: 1972 - 1979 Body Insulator Bushings
Topic ClosedINFO: 1972 - 1979 Body Insulator Bushings
occupant View Drop Down
Direct Link To This Post Posted: 05-July-2010 at 11:06AM
Something we could do is build up a TECH ARCHIVE of the important, but not posted on often, threads that contain vital information. Stuff like the links to the 335 engine website, this body mount thread, etc etc. They can be copied over and made to be read-only or something and in their own forum. Or left in a single stickied thread up top. Then leave the original where it was for discussions about it, and have links to the discussion thread from the "tech archive" thread.
steve View Drop Down
Direct Link To This Post Posted: 05-July-2010 at 11:33AM
 wwhhooaa  That sounds wwaayyy to confusing to this old dawg.
Direct Link To This Post Posted: 05-July-2010 at 1:02PM
What I'm saying is instead of having six stickied threads up top, have ONE stickied thread that contains links and titles for the important threads. The threads may move around and get hits or not, but when you're looking for tech advice or a how-to thread, you could check the ONE stickied topic at the top of the list to see, oh, hey there it is, body insulator bushings, click it, and go to that thread.
Direct Link To This Post Posted: 07-July-2010 at 3:12AM
That's how Hotrodders.com is. I guess whatever the tribe wants (and Scott approves of).
My initial question is still open. Who has actually tried to use any of these body bushings?
Direct Link To This Post Posted: 03-August-2010 at 5:52AM
UnhappyWell...small update:
For those out there following my messed up, screwed up 9 year build, the bushings I bought from Ford, for the radiator support, I would now suggest an alternative.
I was working on my AC system last week, and while under the car I noticed the 5 year old bushings deformed from what I can assume is too much pressure or weight.
So much for getting a body bushing from Ford thinking yeah, that's the ticket!
Andrew
Direct Link To This Post Posted: 03-August-2010 at 7:46AM
Show us what you mean Andy
Direct Link To This Post Posted: 28-September-2010 at 2:29PM
  Good thing that when I did my frame I left the rotted out rad mounts on it. Went thru sandblasting / POR / primmer / and undercoating. Everything from front to rear was removed except them. Left them because I was unsure ! Now I am putting new stuff and theyre still sitting there waiting ???
72 gts fst bk in 1982 !!
currently building 73 fast back with a dove-a 429.
Direct Link To This Post Posted: 28-September-2010 at 2:34PM
Stern Smile
Direct Link To This Post Posted: 17-October-2010 at 2:36PM
OK, sorry for the delay, to outline what I did on just the radiator support.
I finally found the pictures and actually got them grouped together.
So, here are the body bushings I located at a Ford dealer.
stuck a body washer in the open end:
Using a new bolt identical to the original length:
This had some of the body spacers off my original support for this:
Last time I was under the car, I noticed this:
Needless to say, I am not happy.
Need to check into other suggestions like the CV mounts.
Another winter project I guess.
**edited posting as all the original links were broken.
Here is the shot of the updated bushing I used, as described in the other thread:
Edited by Eliteman76 - 21-April-2012 at 9:12PM
Andrew
Ron Earp View Drop Down
Direct Link To This Post Posted: 11-December-2010 at 11:12AM
Guys, maybe this thread needs splitting into radiator mounts and body mounts. Two completely different animals here.
With respect to a 72 GTS I'm interested in what to do about body mounts. My body is going back on the frame in about three weeks and I will need to solve this problem for sure. Unlike most of you it seems I do not have access to a salvage yard to walk around in and compare parts.
A couple of questions:
1) Does anyone have the body diagrams shown at the start of the thread with the thicknesses of the mounts? I can't seem to make out the thicknesses.
2) The Crown Vic body mounts - they work but in some places might be 1/8" to 1/4" too thick?
3) I understand the mounts that are between the frame and the body. What is inside the frame?  When I removed my body what was inside the frame was so badly rotted I can't tell how thick they were nor what they really looked like.
04 Ford Lightning
72 GTS BB Stroker & Toploader
98 Mustang ITS SCCA #38
08 Buell Ulysses
GT40s.com
73GTS View Drop Down
Direct Link To This Post Posted: 11-December-2010 at 11:38AM
Jim
Direct Link To This Post Posted: 12-December-2010 at 12:40AM
Excellent Jim!
I have a question about your example and used your photo to assist. The thick blue line represents the top of the frame rail.
1) Do I have the basic idea correct?
2) Do I need the "top" washer, the one that would go between the body and the mount?
3) Is there enough access from the bottom to actually get the lower mount into the frame? I don't remember the holes being that large but I also don't know how big a round these pieces are.
04 Ford Lightning
08 Buell Ulysses
GT40s.com
Direct Link To This Post Posted: 12-December-2010 at 5:06AM
Excellent Jim!
The nut and washer in RED is not used when mount is installed. I used it for illustration only. (Yellow) rubber mount will be between the frame and body. BLUE circle is the under frame mount. I have it in the rear location, but it will fit perfectly through all frame holes. BLUE line is the frame. If you look carefully at the mount in yellow circle, you can see the silver steel sleeve. That is what goes between the body and this mount.
Jim
Direct Link To This Post Posted: 12-December-2010 at 7:28AM
Hey Andy... IMO, you sure they aren't supposed to bulge like that OEM? If the height is correct and it doesn't move........ *shrug*
Direct Link To This Post Posted: 13-December-2010 at 1:59PM
I don't know.
One of my problems I am having...the front end of the front clip seems like it's move a hell of a lot.
Andrew
Direct Link To This Post Posted: 09-September-2011 at 5:31PM
If anyone is interested I decided to take a shot using 68-72 Chevelle body mount bushings. The size is a decent match. I didn't have to trim anything but I did have to prep 4 spares (?) that came with the kit so I had 10 matching ones. Should know all there is to know next weekend.
91 F-150
torkair View Drop Down
Direct Link To This Post Posted: 20-April-2012 at 5:42PM
I am in need of radiator core support bushings, the ones on my Ranchero are totally trashed.  Any recomendations?
Direct Link To This Post Posted: 21-April-2012 at 3:32AM
Yeah, read the "update" post
Jim
Direct Link To This Post Posted: 21-April-2012 at 9:13PM
Fixed the broken links on my debacle.
inserted images.
Andrew
BackInBlack View Drop Down
Direct Link To This Post Posted: 21-July-2012 at 9:53AM
Anyone have pics using with the Energy suspension bushings mounted on their car?
I'm working on replacing the bushings right now and noticed that the over all height is different and so shimming to align will be necessary.  Problem is...now where do I get the shims?   The old bushing stack has a large spacer with a couple shims.
Right now...waiting for paint to dry...argh   90%+ humidity sure slows things down.
-john
-John
1973 GTS
