  New Posts New Posts RSS Feed - INFO: 72 - 79 Gauge Clusters and Wiring
 Post Reply Post Reply Page  <1234 9>
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2011 at 6:04AM
I had done the swap to Blue LEDs on my cluster, removing the diffuser caps, but I had fought tooth and nail with my turn signal lights of all things.
I ended up keeping the 194 bulbs in the turn signal sockets.
Otherwise, no issues.
I took my cluster comletely apart, used a old toothbrush, and dish soap.
I had to clean my dash out before powertour, amazing how much body dust had settled in the dash that made things a mess. And keep in mind, my GTS was painted 2+ years ago.
occupant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2011 at 7:22AM
Originally posted by 76 cougar 76 cougar wrote:
I wonder if you spray the inside with chrome paint if it would help.
That's what the 73-87 Chevy truck guys do. It works well if you tape everything right.
http://www.73-87.com/7387garage/interior/dashlights.htm
This is on my to-do list but I'll be sourcing a better, non-crumbling, non-flaking, uncracked cluster to do it with. That and figure out why my lights don't work to begin with, which will be SO much easier in a garage.
crispy23c View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crispy23c Quote  Post ReplyReply Direct Link To This Post Posted: 20-June-2011 at 3:56PM
I blew out the whole gauge pack, cleaned every connection, blew out the cluster with air and careful cleaning with a microfiber cloth, selected best gauges... and the lighting is...meh.  Think I will replace with LEDs and be done with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2011 at 5:53AM
Chris-
Night and day difference.
Makes a big difference early AM and also dusk.
I've had a fair amount of guys asking me locally, and any car/truck can benefit from an LED swap in the cluster.
For me, not that I would consider it a safety issue, but I sure like being able to see my cluster.
BackInBlack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2011 at 8:26AM
Regarding the light intensity of the dash lights in the previous post...
I also found that I had to replace the headlight switch.  The old reostat (variable resistor) in the switch was loosing over 3Volts to the dash lights.   I replaced the switched and only dropped about 0.3Volts.
I bought my LED dash kit from http://www.hipoparts.com/   They sell a complete kit with very nice instructions.   You can probably save $20 but you have to buy loose packs and will have extra left over.  I also bought the needle paint from them for about $2.50 (if my memory serves me.)  It was great talking to the guys there (i think his name was Bill).  He is a Ford guy and a cleveland engine fan.   I talked to him about cleveland engine builds for over 1.5 hours.
I dont regret spending the little extra money.   The instructions were very helpful and well thought out.   I would buy from them again in a heart beat.   The kits came with all the error lamps, turn signals, dash lights....everything in the correct colors.   You can buy it as a blue led kit, but I chose the stock color that works with the diffuser caps in the instrument cluster.
Currently my tach isn't working correctly.  Its 500rpm to low and the clock doesn't work.   You can get those replaced at http://www.redlinegaugeworks.com/custom/.   Its a bit expensive.  they use the guts from a VDO gauge for the tach.  The did the gauge cluster for the PureVision Torino.
I figure if I have to spend that much money I might fabricate my own gauge cluster and use good gauges like Autometer, etc.   I'm undecided at this point and I rather spend the money on the rear differential at this point in time.
Hope this helps...The most difficult part of the gauge restoration is getting a "clear" cluster lens.  Most yellow badly and you can't buy replacements anywhere.
-John
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 21-June-2011 at 12:48PM
I have a HiPoParts kit in my car as well. Works excellent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote crispy23c Quote  Post ReplyReply Direct Link To This Post Posted: 22-June-2011 at 1:27PM
Andy & Paul, I ordered the HiPo gauge LEDs today, I probably won't have time to install this weekend, but I am pumped to actually be able to see my gauges clearly.  Thanks for the advice, I emailed them a question and they answered within 5 minutes today.  Good guys, too!!!
~Chris
73sportAZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73sportAZ Quote  Post ReplyReply Direct Link To This Post Posted: 30-June-2011 at 2:25PM
CryPlease help, I have a 73 gran torino sport and am trying to upgrade the instrument cluster to the full set of gauges, I thought it would be sort of plug and play but I have quickly figured out this is not the case. I need a wiring diagram for the instruments. Does anyone know a site to get this info?
AZteacher1973GranTorinoSport
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2012 at 10:36AM
Took my sports cluster off and half the bulbs are missing. Any know the the amps across the board?
73MONTEGO
Ranchero Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2012 at 10:43AM
  Search in the "HOW to SECTION" of this forum, there is a sticky there on this with diagrams. It should cover your ?'s
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2012 at 10:44AM
Oh, I forgot, Welcome to the site
Zebra 3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 7:21AM
I am going to start my project here in a few days...I am going to begin with gauge clusters and wiring first along with the fuel level sending unit.   I have a few questions before I begin.  I am replacing the original ,crumbling, standard cluster in my '76 with a '74-'76  gauge cluster
Originally posted by Psquare75 Psquare75 wrote:
Part 5:
Wiring:
For those that are retrofitting a gauge cluster into a standard dash car you need to change the oil pressure switch with an oil pressure sending unit and then install the tachometer and ammeter wiring above. The final item required is to tap off of your cigar lighter power feed (light blue / white stripe) for clock power.
I understand that it is not as simple as a "plug and play"...so lets make sure that All I will have to do, sans any unforeseen incidents is:
1) Change the oil pressure switch to an oil pressure sending unit.
2) Re-wire the tachometer and ammeter as per the illustrated text
3) Tap off of the lighter power feed for the clock.
Am I correct so far or did I leave something out?
  The fuel sending unit is in unknown condition...I know that the wires in the trunk area are damaged/cut.  My first goal is to get the cluster working properly before moving on the fuel sending unit.
  ANY input and/or help is ALWAYS appreciated and welcomed...and THANKS!!!
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 9:26AM
That's pretty much it. The ammeter harness is the hard part, IMO.
If it were me, starting from scratch (I did), I'd have the ammeter converted to a voltmeter and bypass all that ammeter nonsense.
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 9:53AM
I love that wood burl look-I sold one to someone on here-now I wish I had kept it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 10:48AM
Thats makes a lot of sense to me as well....is there a voltmeter that could be used as a direct replacement of the ammeter that is readily available?
Edited by Zebra 3 - 04-March-2012 at 10:54AM
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (1) Thanks(1)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 10:54AM
Rocket Man can do it
He does the conversion, I think it was $40
Edited by Psquare75 - 04-March-2012 at 10:55AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 1:28PM
THANK YOU Psquare75!!! Big smile  That is exactly what I will do.   Is there any suggested positive wire that I should tap into or just find one that is ignition switch controlled on/off to advoid draining the battery.
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 04-March-2012 at 9:37PM
When I got the gauge from him, he did send a sheet with a small wiring diagram.. but I think I just did as you said, found a wire that was 12v with key on and accessory.. Not the gauge cluster power wire, however. I can't recall what I used, maybe the wiper power wire. Been awhile.
I have had two gauges completed by RCC. I don't know if he offers a face for the 72-76 gauge, (He focuses on Cougars and 73-79 F100) but to be honest, his gauge conversion puts 12 volts at "0" on the ammeter. The face isn't that important, but a nice touch. I'd contact him. He does very good work. He takes a small voltmeter and adapts the OEM face and needle to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 05-March-2012 at 1:54AM
Great info. I, too, am converting from standard gauges to the Sport gauges and will need this!
I have another question: I bought a complete set of Sport gauges without the white cluster holder - pod? - (for lack of a better term) or in other words, each gauge is individual and sitting in a box. They were pulled out of a lady's car years ago by her son when it was smashed by a tree in a storm (33K miles). The guy is now older and could not remember the year of the car. Being that these are individual gauges, will it make any difference what year pod I install them in? Mint condition and it would be a shame to waste them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 07-March-2012 at 10:52AM
Not sure. I'd match it up to what tach you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2012 at 12:56PM
I got around to replacing the stock dash cluster (the white plastic part was so brittle it was breaking from it's own weight) with the appropriate sport cluster...I have one question....should I also replace the temp. switch with a temp. sending unit since I am changing over from warning lights to gauges?  I noticed that the temp. gauge was all the way over to the "H" even though the engine is cool.
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2012 at 1:26PM
If memory serves, doesn't the base model non sport cluster have a gauge for temp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote occupant Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2012 at 2:30PM
Yes, fuel-speed-temp, odometer, turn signal indicators, and some idiot lights, that's all you get with the 3-hole base cluster. Clock was optional in the extra hole on the right but it doesn't affect the rest of the cluster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranchero Fan Quote  Post ReplyReply Direct Link To This Post Posted: 21-April-2012 at 2:40PM
The only sending unit that has to be changed when you convert to the optional gauge cluster, is the oil pressure sender. Did the temp gauge work with the standard cluster? If it did, then you may have an open wire, bad gauge, or the sender coincidently went bad. Try the simple things first. Sorry that's all I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 22-April-2012 at 4:27AM
  YES it doesEmbarrassed ...my bad... I should have paid closer attention to detail.
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2012 at 4:34PM
Originally posted by neejah neejah wrote:
For posterity (fitting a '74/'76 cluster into a '72) -
Pin PCB Connections ('74-'76) Car ('72)
Purple/White (Brake) Purple/White
2 Red/White (Eng Temp) Red/White
3 Blue/Red (Illumination) Blue/Red
4 Black (-ve supply)
5 White/Blue (Right Turn Ind) White/Blue
6 Green/White (Left Turn Ind) Green/White
7 Green/Black (High Beam Ind) Green/Black
8 Black - Don't Splice (+12v) Black - Don't Splice (+12v)
9 Yellow/White (Oil Pressure) White/Red
10 White/Red (Fuel) Yellow/White
11 Green/Red (No connection on PCB) Green/Red
12 Yellow/White (Top RH Warning Lamp)
13 Green (Btm RH Warning Lamp)
14 Red/Yellow Dash (-ve) Red/Yellow Dash (under hood conn.)
Notes: Pin 14 & Pin 4 I routed to a new ground - the harness for pin 14 terminated in an underhood connection which didn't go anywhere.
Pins 12 & 13 I haven't connected at the minute - I might use them for a shift light at some point in the future.......didn't really care about the fasten seat belt warning!
Hopefully it might help someone in future.........
Neil
    Yes, this has been a huge help for me!Big smile......but I have a couple of corrections for the printed circuit board (D4GF 10C956 BA) 1974,1975, some 1976.....
I am doing a retrofit of the instrument panel circuitry on my '76 (born on date 4-9-76)
#9 Pin circuitry goes to the - (ground) side of the fuel gauge
#10 Pin circuitry goes to the -(ground) side of the oil pressure gauge
#12 Pin circuitry    there is an aprox. 1/4 break in the circuit on the PCB next to the plug in terminal block...I checked 2ea. D4GF 10C956 BA PCB's and the break is the same and in the same spot. The #12 circuit is the + (positive) for the Parking Brake light bulb...located in the top Right hand location of the instrument cluster.
This one has me baffled...there is no other power source for the light bulb ( looking at the PCB) yet this light and the one below it (seat belts) share the same common ground circuit.
#14 Pin circuitry goes to the - (ground) side of the brake warning light (pressure),parking break light and seat belt light
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 29-June-2012 at 2:45AM
I can't speak for the early cars, but the 77+ cars, the top right light is "Door Ajar" and it's a stand alone bulb/harness/socket that snaps into the hole.
Edited by Psquare75 - 29-June-2012 at 2:45AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 4:20PM
This is the wiring information for the STANDARD instrument cluster (warning lights w/ Fuel and Temp. gauges) The pin numbers corresponds with the numbers on the terminal block that plugs into the printed circuit board (part # D6OF-10C956) I used the terminal block from my Torino (born on date 4-9-76)
This information should prove to be valuable for those who are converting from a standard cluster to sport cluster ('74-'75-some '76) OR trouble shooting the standard PCB. '74-'75-some '76
LOCATION     COLOR(S)                               CIRCUIT INFORMATION
PIN 1 Red w/ Yellow hatched marks        ground side (-) of brake (pressure) & oil pressure light socket
PIN 2 Green w/ Yellow stripes                                           positive side (+) of fasten belt light socket
PIN 3 Light Blue w/ Red stripe                                             positive side (+) of the dash light sockets
PIN 4 Black                  ground side (-) of the dash,fasten belt,high beam and turn signal light sockets
PIN 5 White w/ Light Blue stripe                         positive side (+) of the Right turn signal light socket
PIN 6 Light Green w/ White stripe                         positive side (+) of the Left turn signal light socket
PIN 7 Light Green w/ Black stripe                                positive side (+) of the High Beam light socket
PIN 8 2 EA. wires Black      positive side input (female connection on PCB) instrument cluster voltage
                                        regulator
PIN 9 Yellow w/ White stripe        ground side (-) of fuel gauge
PIN 10 Light Green w/ Red stripe                 Pin's 10 and 11 both go to the alternator light socket.
PIN 11 2 EA. wires #1 Dark Green               The measurement between pin's 10 and 11 is in Amps.
           #2 Gray w/Yellow stripe                   The light is part of the curciut "loop' between pins 10&11
PIN 12   Red w/ White Stripe                                               ground side (-) of the temperature gauge
PIN 13   White w/ Red stripe                                         ground side (-) of the oil pressure light socket
PIN 14   Purple w/ White stripe                            positive side (+) of the Brake (pressure) light socket
Unlike the sport cluster, there is no circuitry for the parking brake light with the standard cluster PCB
Edited by Zebra 3 - 01-July-2012 at 4:47PM
Henry Ford. 1926
Brian Conn
'76 Torino
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zebra 3 Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2012 at 4:46PM
This is the wiring information for the sport instrument cluster. The pin numbers corresponds with the numbers on the terminal block that plugs into the printed circuit board (part # D4GF-10C956)
This information should prove to be valuable for those who are converting from a standard cluster to sport cluster ('74-'75-some '76) OR trouble shooting the sport cluster PCB. '74-'75-some '76
LOCATION                         CIRCUIT INFORMATION
PIN 1                      positive side (+) brake (pressure) light socket
PIN 2                     ground side (-) temperature gauge
PIN 3                      positive side (+) dash light sockets
PIN 4                     ground side (-) all light sockets except parking brake and fasten belt
PIN 5                     positive side (+) Right turn signal light socket
PIN 6                     positive side (+) Left turn signal light socket
PIN 7                     positive side (+) high beam light socket
PIN 8                    positive side input (female connection on PCB) instrument cluster voltage regulator
PIN 9                    ground side (-) fuel gauge
PIN 10                  ground side (-) oil pressure gauge
PIN 11                  NOT USED...NO CIRCUIT ON PRINTED CIRCUIT BOARD
PIN 12                  positive side (+) parking brake light socket
PIN 13                  positive side (+) fasten belt light socket
PIN 14                  ground side (-) brake (pressure),parking brake and fasten belt light socket
Henry Ford. 1926
Brian Conn
'76 Torino
Srandaz2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Srandaz2 Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2012 at 9:24AM
This is excellent info, but I am afraid I am a bit confused. So here's my dilemma I purchased a 1977 sport dash for my 1975 gran Torino. I plugged it in and everything seemed to work until I seen my fuel gauge go to 3/4 and the temp gauge went completely to the right - passing behind hot. As for the tach and amp gauge I already assumed I would be rewriting those two .... Can anyone help me here? The guy I bought it from is willing to accept the return but he doesn't have a 1975 / 6 dash and I would really hate to send it back if I can still use it.........any assistance would be greatly appreciated
Steve
This page was generated in 0.266 seconds.
