INFO: Big Block Motor mounts |
Page 12> |
carl3oo6 ![]() New Member ![]() Joined: 26-September-2012 Location: NJ Status: Offline Points: 11 |
![]() ![]() ![]() ![]() ![]() Posted: 21-May-2016 at 5:05AM |
Hi all, I have a 76 gran Torino. Came with a 351 Windsor . As of now the big 460 is being built. I ordered a set of big block mounts from Dearborn. They look to be quality mounts. The instructions say to drill out where the Mounts go. has anyone ever done this? Any photos would be greatly appreciated. Also soon to be ordering up the six speed manual transmission. I should apologize to all for not posting pictures of the build , I've done quite a bit.
californiajohnny ![]() Moderator Group ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 13131 |
well then you need to start a thread and catch up on the pics
MrSmog ![]() Senior Member ![]() Joined: 21-January-2016 Location: Ky Status: Offline Points: 1306 |
Sounds like those aren't the right mounts if you have to drill a hole, they may "work" but is the engine really located properly in the chassis?
Past 1974 Ranchero GT Q code
Present 1973 Q code formal roof base model Torino with ralleye equpiment package and 4spd. |
Nuggets ![]() Senior Member ![]() ![]() Joined: 07-November-2014 Location: UK Status: Offline Points: 869 |
The Dearborn mounts are actually Crites ones with a marked up price
Barnaby
429 powered 73 Stripper.....no comfort, just noise! |
Big Bird ![]() Senior Member ![]() ![]() Joined: 25-August-2013 Location: New York Status: Offline Points: 3883 |
Something's not Kosher with those mounts.
Should be no drilling involved.
they should be a direct drop in
Barnaby
aquartlow ![]() Senior Member ![]() ![]() Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2032 |
I'd just buy the tinman fabrication ones if I was looking to chop out the old engine crossmember
Was looking for a drop in solution when I was building the car though....got bored of the whole fabrication lark
Barnaby
The Crites ones are pretty much the fullsize mounts with the ears cut off bolted to some brackets (the grey parts). All the load is on a small bolt that holds the two together.
Realistically, you could use the fullsize mount by using the frame half of the fullsize mount and weld it to your frame, or attach it to a plate that bolts thru the torino chassis. Not a lot of sense involved in some Ford mounting schemes. They re-invented the wheel over and over. |
I'm not a fan of the 3/8ths gap either side of the ears either....could have made it a lot better on tolerance same with the 1/2" space between the mount and frame top
Barnaby
They were much cruder when they started years ago...
As far as the ear gaps go, 74-up frame is wider, so the mounts are "loose" on the early frames. Cali-Johnny had to cut/weld his 72-73 performance mounts to fit his later frame.
yes, i think the 74 was about 1/8 or 3/16" wider than the 73
Stock mounts are still around to use, why not use what the factory did?
try finding them at a good price
Barnaby
Power Surge ![]() Senior Member ![]() Joined: 06-March-2016 Location: Palm Coast, FL Status: Offline Points: 542 |
Well, it's been 20+ years now, but I took a 460 out of a 74 t-bird when I was in high school and it bolted right into my 351w 75 Torino with the stock mounts. Are they not available anymore?
Sal Mennella
None reproduced, and the donor pool is drying up. Crites is available, but leave something to be desired. Engine doesn't sit the same as factory, which means aftermarket header fitment is off. Crites does make headers to fit their mounts, but they don't fit anything else and they are expen$ive.
They are easy to find, just have to learn to search. lots of people partin the 72-76 t birds and lincoln marks which all had 429 or 460's. I have a line on 3 sets of them which i'll have soon. not as expensive as you'd think either. |
Give me a price on the best set. If they're right then I can produce a few sets which are dimensionally accurate unlike the Crites ones
Barnaby
yea i'll keep ya in mind when I get them. I'm waitin on the guy to start tearin his parts cars down.
You don't even need to send me a set man, just a dimensioned drawing. I'll knock some up a batch at club rates if people want some
As long as my materials are covered I'm happy to engineer stuff |
Barnaby
DaleR09 ![]() New Member ![]() ![]() Joined: 23-July-2016 Location: Enumclaw, WA Status: Offline Points: 31 |
1976 Ford Ranchero 460 motor mounts, NAPA part #BK 6021288. $15.00 ea. Try them
CJJ ![]() New Member ![]() ![]() Joined: 10-January-2021 Location: Canada Status: Offline Points: 34 |
These part numbers for motor mounts be good for my 76 Torino? Right side mounts D2LA-6038-BB. Left side D4SA-6B032-AA and another number, not sure why? D5OA-6B032-AB
72FordGTS ![]() Admin Group ![]() ![]() GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Offline Points: 4219 |
From the Ford Master Parts catalog, it shows the following part numbers:
Bracket: D3LY 6030-A (RH), D3LY 6031-A (LH) Insulator: D40Z 6038-J (RH), D4SZ 6038-A (RH) 1974-76 Insulator: D4SZ 6038-A (RH), D4SZ 6038-B (LH) Shield: D3LZ 6C038-A (RH), D3LZ 6C038-B (LH) |
man! Thanks, guess I’m gonna have to search further into this. I wonder if those numbers I’m looking at will also work? Not sure what they are from?
I am assuming the part numbers you have is for the whole assembly, all three parts together. The parts catalog only lists them individually. However, you could always ask the seller to check the Ford part numbers on each of the parts.
thanks!
Understand that there are several part #s for the mounts and several for the engine brackets. Later parts books will show the superseding numbers only. Mounts were a D2- part # originally, and they were superseded in 74 as a D4- number. The engine brackets were originally an earlier part used to mount 429 engines into a chassis that used a bracket and insulator to install FE engines. This let them share the insulator in the earlier chassis. This earlier engine bracket does not have the 3-sided well for the bracket-to engine bolts. These were bending, and were redesigned in 73 and have numbers starting with D3. Not sure of the part numbers for the earlier ones, but the set on Ebay has the older right bracket. I believe the originals were to put 429s into Mustangs, but not 100% wether Mustang or Torino. There may be several versions, as Mustang mounted the engines lower in the chassis than Torino. I do know that the full set of FE parts, plus the chassis bracket/knuckle will let you put an FE in a 66-69 Falcon with a little fiddling.
wow great info!! Ya I just found Ford started alphabetical on their parts in the 40’s hence the D for 70-79 which I’m sure you already knew! Thanks for the help. I see a set on Mac auto parts, just not sure if they’d be strong enough for a 500hp 460??
Just to further update this thread, here are the 1972 part numbers:
Mounting Bracket (Torino and Thunderbird): D2OZ 6030-B (RH) D2OZ 6031-B (LH) Insulator (Torino) D2OZ 6038-E (RH) D2OZ 6038-F (LH) Insulator (Thunderbird) D2LZ 6038-A (RH) D2LZ 6038-B (LH) replaced by D4SZ 6038-B
Page 12> |
Tweet
