  New Posts New Posts RSS Feed - INFO: Manual Transmission Pedal from MDL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2019 at 4:05AM
Always great info. Would be great to see pictures.
One of my complaints with my GTS has been I had to modify the headers I had for my car.
I had old Dynomax Blackjack headers on my 1976 Ford Elite with my 351C and C4, but I figured when I put my engine into my GTS, I figured I had nothing to lose by chop-cut-weld into my 4 speed car. Took a bit of figuring out but I made a new pipe then had an exhaust ship bend me one up and I burned it into my header, to clear the Z bar.
I've discussed with Paul at Modern Driveline and John [BackinBlack} and with our clutch pedal, the travel/ratio is supposedly quite ideal compared to some other setups out there.
I'd love to see your Pedal set conversion however.
As I've driven Foxbody's 87+ and also the SN chassis 2000-2001 GT with a 5 speed, I can say I loved the 2000's clutch feel. Granted it was a 4.6 GT with a hurst short throw shifter on a T45, and not my 351C/Toploader or the Tremec TR3550 combo.
Andrew
mean steve View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mean steve Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2019 at 4:28AM
The peddle that he designed is like how I originally started. Not a bad idea but it was the same thing for me, the headers. So everything started to get expensive. Not a fan of the snowball. Wss looking at hydraulic and decided the cable was the cheapest best way to go. Worked out great. 2000 mustang donor, paddle to throwout bering. I'm working on pictures (whole different story)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2019 at 4:24AM
PN MD-402-7276T-C doesn't pull up on their page yet Ermm
BackInBlack View Drop Down
Post Options Post Options   Thanks (2) Thanks(2)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 30-September-2019 at 1:00AM
I went hydraulic because there just isn't much room to work with around the brake booster.
I had to switch to hydroboost to make room.  The hydroboost is nearly a bolt in replacement.   One bolt hole had to be elongated.
You can see the slave cylinder is really close to the mounting location of the brake booster, within 1/4 inch when assembled.
The position of the slave cylinder is perfect to allow the connecting rod to swing in an arc without binding.
It works perfectly.  I have no regrets.   I had to fabricate a push rod for the brake booster to master cylinder.   This is one of the places that sells a kit for a torino.
I also had to relocate the booster pin on the pedal to the correct height.  It is bascially 1/2" close to the pivot than the automatic pedal pin distance.
I hope this helps.  I was planning on doing some guide on this swap but i never seem to have the time.   I've been swamped trying to get my car to the paint shop combined with work and life.
BTW...I would also highly recommend welding in a sealed bearing race in the pedal brace to replace that plastic bushing.   I had mustangsteve.com do mine since I didn't have a welder at the time.  Well worth the extra money and effort.
Anyone have a better picture hosting service?  Photobucket is messing up the pics and trying to charge you for storage, even though they take ownership of your pics.
Edited by 72FordGTS - 02-October-2019 at 12:23PM
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2019 at 9:53AM
Whats the deal with photobucket....anyone have a recommendation for another pic host service?
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2019 at 12:24PM
Photobucket is nothing but problems, it ruined a lot of threads on here.  Your best bet is to upload the photos to your file manager on this site.  That way they are always available.  There is a how to thread and Californiajohnny even made a video if you need some help with the upload process.
I fixed your photos above.  They have been uploaded to the site now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-October-2019 at 3:28PM
happy belated birthday john Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 03-October-2019 at 6:33AM
Wow...thanks bud!   You're not late.   Its in 7 days  Smile.   I hope to update some threads here soon.   My car is getting painted now.   I can't wait!
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 17-October-2019 at 4:45AM
The clutch pedal not being listed on MDL's site has been something I have brought up, however you have to call them and just order it.
Also, modifying a set of headers at least for me wasn't a huge nightmare but the factory Z bar can be a PITA.
However, I plan on working on mine as well over the winter.
My GTS needs some attention in multiple spots. 10 years of bangshifting on the street, there are dues to pay...
Andrew
