  New Posts New Posts RSS Feed - INFO: Suspension Part Numbers (stock replacement)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2014 at 12:59PM
You probably could. We used to get the whole assembly and swap it. when we were doing this, torinos were fairly new and usually had good ball joints, bushings, etc. This kept all the parts single source for replacement down the road, and the ball joints LOOKED different so...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2014 at 10:33AM
clarify please;
1975 LTD spindles on a 72 Torino will use 74+ Torino 10.7" rotors
1975 LTD caliper brackets on 1972 Torino spindles will use 1972 T-bird 11.8" rotors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2014 at 12:50PM
On a 1972 torino, a 1975 spindle will allow use of any big bearing rotor. (5x4.5 bolt pattern 10.7 rotors OR 5x5 bolt pattern 11.8 rotors)
spindles are the same as follows - 1973 up to 1978 in fullsize ford, 1973 to 1979 intermediate. (Reportedly SOME early 1973 models may use the earlier spindles/bearings)
caliper brackets from 1972-1976 Thunderbird/Mark IV, 1977-79 Mark V with 4 wheel disc, or 1973-1978 fullsize will bolt on and allow use of big rotors. If you use 1972 spindles, you can use 1972 thunderbird rotors and have a 5x4.5 bolt pattern.
1975 LTD caliper brackets will allow use of 1972 torino spindles with 1972 thunderbird rotors. (as would 1972 thunderbird caliper brackets)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2014 at 1:21PM
I hope that's a Yes cuz I just pulled the trigger on these
http://www.ebay.com/itm/181308663596?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
with my small brackets & 75 spindles I can run $30 rotors
with the big brackets & 72 spindles I can run $120 rotors
so far I like this deal, Blueoval wants $220 for just the big brackets
Edited by Rockatansky - 21-February-2014 at 1:23PM
carguy47 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carguy47 Quote  Post ReplyReply Direct Link To This Post Posted: 31-July-2014 at 12:57PM
I did the same. Started with a hole-saw to loosen the rubber. Heated them with a torch and then sandblasted the sleeves. Inserted the poly bushings.
Joel & Becker Wilson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joel & Becker Wilson Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2020 at 3:24AM
Wow, great information, love and appreciate the legwork. I found Moog online as well as Energy suspension parts which carries a complete polyurethane kit. ESP does mention that poly is a stiffer ride and more road noise. I love the idea of a kit though. Has anyone used the ESP or poly kits? Is Moog the way to go? I haven't seen a kit yet. If I order the prescription in this thread, it should replace all the rubber in my suspension?
Thanks for spoon feeding me.
Joel and Becker Wilson
72 GTS 351 Cleveland 2v
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2020 at 7:37AM
i have poly in my car and most all my other cars, easier to replace and last longer impervious to gas and oilWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2020 at 9:59AM
For the rear suspension, poly is all you can find anymore for the upper control arms.  Most of the replacement rubber bushings are no longer available, unless you find some old stock.  The rubber lower bushings are not adjustable for pinion angle like the OEM bushings.  The poly does stiffen up the rear end quite a bit, but it also keeps the rear axle well planted, eliminates any lateral play, and usually gets rid of wheel hop issues.  You can still get rubber for the front suspension but poly is also available.  As for the poly kits, I used Energy (black) on my car, no complainants at all.  I also used Moog and Spicer for all my front end components.  All were good quality, but probably more money than buying a PST kit.
texanrebel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Posted: 06-November-2020 at 11:27PM
FYI - I came across this sway bar bushing from Inline Tube part # INL13148. It's listed for a GM 1-1/8" bar. I ordered out of curiosity and it seems to be a perfect fit for my 72 with competition suspension using the factory brackets. I have not installed it yet, but looks like a good substitute.
1972 Montego GT
1977 Mercury Monarch
1988 Ford Thunderbird Turbo Coupe
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2020 at 9:22AM
If those will fit the frame mounting bracket, they will work.
I still have the 1.25" front bar I bought for mine. When I get my 2nd one to sell closer next year, I might choose to not use this, and let someone else buy it. I think any big Ford intended for great handling needs a much bigger bar than the factory, best they made size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Posted: 07-November-2020 at 12:18PM
They fit perfect, had to find my original brackets before I knew for sure. Installed them today
1972 Montego GT
This page was generated in 0.092 seconds.
