  New Posts New Posts RSS Feed - INFO: The Coil Spring Thread
 Post Reply Post Reply Page  <1234 20>
interceptor460 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote interceptor460 Quote  Post ReplyReply Direct Link To This Post Posted: 05-December-2009 at 4:55AM
It all depends what year crown victoria PI spring you are looking at. I tried to post photos on this site , but I have a problem doing so as I am not the best on using compters. I could show you ride height of my old police torino or show scans of coil spring specs. Also I had to cut down springs to reduce ride height on my 78 pontiac pheonix. It has a V-6, yet I put V-8 coils and I cut 1/2 a coil to put it a the right height. The end result it rides stiff yet I take turns with no worries.
  My 74 police torino was not so bad in the turns yet it could use improvement. I have to look into all options with a open mind. Last I do not have the CVPI coils specs for 2001 and up. I try to look into that soon.
73GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 05-December-2009 at 7:44AM
Originally posted by interceptor460 interceptor460 wrote:
It all depends what year crown victoria PI spring you are looking at. I do not have the CVPI coils specs for 2001 and up. I try to look into that soon.
MOOG Part # 80090
1998 - 2002 Crown Vic
1998 - 2002 Mercury Grand Marq
Inside DiaBar DiaInstall HeightLoad rate (lbs)Spring Rate (Lbs/in.)Free HeightEnd Type
4.04                           0.781                  11.75                    2034                      710                         14.38                     One Square End and 1 Tangential End
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2010 at 3:36PM
BUMP anyone ever try anything from this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2010 at 3:49PM
Figures I made no effort to bump this back up Paul...thanks.
Reading though this again, I need to read it again...Geek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2010 at 3:51PM
I'm just looking for a simple answer like the chevelle guys seem to do.
Have a big block? want 1" drop? use spring XXXX
2" drop? use XXXX.
Small block? use XXXX.
etc.
Blueoval76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-May-2010 at 8:26AM
I agree I would really like to drop my front end at least 2 inches but would rather replace the coil instead of cutting it since I have a lean and I am not sure if its the front coil.
Jesse
03 Bonneville some mods
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 01-July-2010 at 10:58AM
Ok it is now time to bump this back up. I just ordered NAPA part number 277-3144. From what I can tell I have 2 different height springs in the front so I went to NAPA and the guy made a copy of the coils in the 4.000 - 4.080 diameter range out of his book. So I looked it over and picked one that looks like it will work best to possibly lower my front. I will post back with pics once they are in. The info on the springs is below.
# Coil Spring Coils : 9.13
Coil Spring Free Height : 16.12"
Coil Spring I.D. : 4.04"
Coil Spring Load Height : 10.5"
Design Load : 2329
Spring Rate : 414
Wire Diameter : .705
Jesse
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2010 at 2:40PM
So I finally got my springs put in Friday and it seems a little different but it is really hard to tell any difference at all in the pic. I can tell that when sitting in the car the nose is down compared to before. I did not correct the lean with the springs so the only thing left is the control arms and spindle on the pass side that was replaced with JY parts from a different car that must be a little taller. That will be looked at next year some time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 22-August-2010 at 3:41PM
Have you noticed any difference in handling with the new springs? I went with a set of either 425 or 450 springs from Eaton. I was just curious as yours appear to spec pretty close and I won't get to drive mine for a bit yet.
Sharp looking car. Looks like you tucked in the front bumper, did you do the rear as well?
Edited by lynchster - 22-August-2010 at 3:46PM
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2010 at 3:01AM
As embarrassed as I am to say...
My Cougar from VA had PST 'lowering springs in the car. I loved the stance. Car handled great as well. . I asked the previous owner what he bought, etc.
In his words"
I think PST sent the wrong progressive rate front springs b/c the resulting ride height made the car sit like it was launching on slicks and a 4.88 gear! :) I could sit on either end of the bumper without much of a ride drop. We cut over a coil each side, but it didn't make much of a height difference. The final solution was to heat the bottom of each coil with a torch until it achieved the desired stance."
I hate to say it, but I'm really happy with these springs and I swapped them to my white Cougar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2010 at 10:57AM
The only thing I noticed was that the springs that came out were really stiff and I could barely push them down. The new ones I am able to push down myself. Also the ones that came out one coil was 1/2 a coil taller just as I suspected, but I still have a lean and really think the spindle or one of the a arms are different than its supposed to be.
The front bumper was tucked but I dont think the rear one was.
Edited by Blueoval76 - 23-August-2010 at 10:57AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2010 at 1:50PM
What year is your car? I would suggest getting another spare set of spindles.
I have a set off a '76 Elite floating around, along with I think I have one more pair of 1972 spindles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 23-August-2010 at 4:00PM
It is a 1975. I do know for sure that the lower control arm on the pass side is JY marked something like 74 Ford or something like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2010 at 5:49AM
Man...I don't know. I always considered the lower and upper arms the same on these cars.
Only thing that comes to mind for me...if you are really having issue with the lean, swapping out the spindles, and checking the upper and lower arms, all new bushings and a set of matched springs.
I have yet to come across a bent 72-76 Spindle...but not to say it can't happen.
Andy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2010 at 7:35AM
spindles different at all besides bearing size?
Like... EXAMPLE... using a 72 on a 74 lowers it by 1/2" or something whacky like that?
What about lower ball joint issues?
Shorter sleeve in the control arm making it sit different in the LCA?
Different angles between BJ and Spindle hole, not seat all the way or too far in?
Different BJ's all together? 1 taller than the other?
or... FRAME TWEAKED!?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2010 at 8:27AM
All that stuff is something I would have to look at more, but I do know that the car was set up to lean so that when the 10 sec big block torqued it would sit straight. And I know for sure the a arms on the pass side are different. I will post pics (when I get home)of the front end that I took and maybe someone can tell what is off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2010 at 9:19AM
My Cougar is a hodgepodge collection of 76 Torino steering linkage, 72 Torino spindles, a 71 Mustang steering box, and 76 Torino (Elite) control arms.
It works together wonderfully Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 24-August-2010 at 10:59AM
Ok so here is a few pics of the front suspension and I still dont see a difference except that one coil is bunched up at the bottom vs one being with normal gap. Maybe its just me! Lol!
New springs...
Old springs...
Upper A arms with old springs...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 25-August-2010 at 5:57AM
I see nothing to throw a red flag.
Spring is a bit curious though...the new springs were identical, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 25-August-2010 at 8:10AM
LOL!! That is the only thing that looks off to me too and the springs were identical!Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 25-August-2010 at 11:48AM
the springs are not an issue... look at them, they are just spun around from one side to the other.
Look at where the END of the spring is. the one that looks bound up is at the end where the 2 coils come together as opposed to the other one you are looking at a single coil point with the overlap coil and end is on the other side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 26-August-2010 at 5:35AM
OK, with that being said, did you properly clock the spring?
On the lower arm, there is a pocket where the bottom of the spring slips into.
The flat portion will be on the "top" of the spring, where it's inserted up into the frame pocket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 26-August-2010 at 7:01AM
Don't know as I didnt do the install. I will have to crawl under and take a look. I will see if I can get some detailed pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 26-August-2010 at 12:06PM
That's what I was trying to say. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2010 at 5:56AM
Sorry Carl, I posted that, missed your post!
OK, I need a update: sound off on guys that have RECENTLY bought springs.
I am going to have my fronts as a winter project, and want to check brand and model you used. Figuring I am going to pick up another pair of 460 springs, and remove around 2" this time instead of 4-1/2" worth of coils.
moose0211 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moose0211 Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2010 at 6:36AM
Andy, I have no idea about coil springs and ratios and stuff, but wouldn't 460 springs lift up the front? Psquare always said that he uses small block springs on the front, so wouldn't 302 springs lower the fronts a little on our 351 cars?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2010 at 6:38AM
I think his reasoning is he wants a stiffer spring.. but cut down to an appropriate height. I don't want my car to ride like a truck so I go with the small block spring usually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2010 at 11:08AM
Don't throw away your old springs!
I may be interested in buying some so I have different rates/height for my Dirt Race Car.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blueoval76 Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2010 at 11:56AM
Who is this meant for? My fronts are gone to scrap cause they were cut with a torch. My rears however are in excellent shape and are painted a blue if you are interested before I toss them too. Wink
Edited by Blueoval76 - 27-August-2010 at 11:57AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 27-August-2010 at 1:56PM
I have to go back and check the spring pressures. I have a few, but I need a couple front for a big block car. I can cut them down to height I need.
Stock is not progressive right? So if I cut them, they still have the same rate just shorter?
