  New Posts New Posts RSS Feed - INFO: Tubular Upper Control Arms
 Post Reply Post Reply Page  <1 678
MZSCJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MZSCJ Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2020 at 5:12AM
Has anyone on this site actually installed the A arms from Hotchkiss?
I need to buy tubular arm for header clearance
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2020 at 11:06PM
Didn’t know they made them. Post a link.
-Billy Conturo
BackInBlack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BackInBlack Quote  Post ReplyReply Direct Link To This Post Posted: 22-September-2020 at 11:18PM
I thought Hotchkiss made the a arm for a galaxy but never sold it.  Littleshop was te only shop I found.
-John
1973 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2020 at 12:44AM
Hotchkiss put the arms into production but only list them fitting Galaxies despite the fact the upper arms are the same part number as early1972 Torinos. No one as of yet has tried them to my knowledge. They are very pricey.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-September-2020 at 3:46PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2020 at 2:49AM
For control arms you have to match the ball joint basically, top and bottom.
The spindles are made for certain wheel bearings so obviously only some rotors can work. I hunted for a bigger rotor in the early 80's, and I missed the later 70's choices. I ended up with a 71 Lincoln spindle and rotor, about that 11.75" size, but has a 5x5" bolt circle. I had slot mags back then which have slotted lug nut holes, worked on both ends. But that wasn't a good idea, I'd been looking for a way to undo that since.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2020 at 3:53PM
I doubt those brakes would work. I have all the parts and size and what other cars it interchanges with in this thread:
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2020 at 2:28AM
Thanks Vince, I recall reading a brake thread years ago, that one will help me. I like brake upgrades, and if the parts aren't bad, I do it if I can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 29-September-2020 at 2:47PM
Galaxie a-arm next to a Hotchkis arm (Pic from a thread on the interweb, Grassroots Motorsport)
We used to swap in Torino Knee assemblies (upper, lower, and spindle) to add disc brakes to the 65-68 era galaxies. Hotchkis a-arms and lowers should fit just fine in a Torino. Don't know if Hotchkis is using standard balljoints or some goofball balljoint and spindles, because when i saw the price on them i lost interest.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MZSCJ Quote  Post ReplyReply Direct Link To This Post Posted: 01-October-2020 at 2:36AM
I think the Hotchkis arms come with shafts, bushings and ball joint.
That could be some of the price difference.
chris5769 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chris5769 Quote  Post ReplyReply Direct Link To This Post Posted: 19-June-2021 at 3:39AM
Just had my little shop upper control arms, all bushings, ball joints, springs, shocks, and steering linkage replaced on my 75 Gran Torino.  It drives and handles better than when it was new!
Cheers,
1975 Gran Torino
cad974 View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (1) Thanks(1)   Quote cad974 Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2022 at 3:37AM
Hello
I am new here,
My car is a 1974 FORD GRAN TORINO S&H, with few mods and upgrades.
I just bough 2 upper tubular arm with +4° caster... hope get them soon.
speed id not the limit
spirit is the limit
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2022 at 6:48AM
I am FINALLY getting around to installing mine. Can't wait for this.
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2022 at 1:04PM
I have a set of these for sale since i sold my Torino if anyone is interested. I will save you some money.
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2022 at 5:36AM
Allan, give me a call on that set you have.
72RogerGT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72RogerGT Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2022 at 9:03AM
If Andrew doesn't get the control arms, I will take them let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72RogerGT Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2022 at 9:04AM
If they are still available, I will take then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2022 at 10:39AM
Andrew spoke for them, I am double checking with him now. Will let you know.
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72RogerGT Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2022 at 6:01PM
That is fine, let me know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2022 at 3:09AM
Andy got them Thanks Allan
Allan
Revelation 6:8
forddude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forddude Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2022 at 2:46AM
Hey fellas, are these our only option for direct bolt-in tubular upper control arms?
 They look very nice, however, $600 for a pair is considerable.
72 GTS sportsroof, original survivor
72 GTS formal, parted
96 Tbird 4.6, 18k org mi
13 Stang 5.0 6spd
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 09-June-2022 at 3:16AM
That is probably typical, the cost for late model Ford SUV UCA's is in that $600+ range also.
There are a pair I want for my Explorer, the BTF arms are the standard for those. edit, crap, they are now $699 a pair.
JimC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 06-April-2023 at 1:13PM
Still waiting for them to come into stock.
1972 GTS under construction
galvarado View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote galvarado Quote  Post ReplyReply Direct Link To This Post Posted: 19-September-2023 at 6:30AM
I've been on the waiting list for months now. Little Shop told me they'd email me when they were back in stock. However I just checked their website and it states they're no longer producing the control arms and that the design was sold to Michigan Metalworks. Not sure if anyone was aware.
Compton View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 19-September-2023 at 7:41AM
I’ve got the Hotchkis Galaxie arms on my car…they fit perfectly…had to wait a couple of months for them also but they’re still in production…about the same price..quality is top notch and come with bushes and ball joints etc so maybe better value….literally bolt on
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 3:13PM
At the time, I had to pay a bit more originally because I missed the initial buy-in with Little Shop.
Sad they decided to stop making them, but then again, we're not the Camaro/Mustang crowd.
Compton, do you have a list of specific part numbers?
I also need to look at Hotchkis strut rods.
My front end rebuild was put off, as I was missing a few pieces.
I will say RockAuto, I had $100 into just the Moog ball joints. Was shocked they were still Domestic USA made.
Regarding the 72-79 Torino/Ranchero spindles, it was really common to swap the spindles onto Galaxys and the like of Torino/Ranchero vehicles. Our spindles are considerably more beefy than Granada stuff.
Additionally, the 72-79 intermediate spindles are great easy upgrades for the shoebox era Fords and Mercurys from the 1950's. All that's needed is the correct ball joint reamer to match the taper of the stock shoebox ball joints.
Long time friend in the Omaha, NE area used to constantly buy all my spare spindle setups to update his fleet of shoeboxes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 27-September-2023 at 3:22PM
Man, this aged like spilt milk on a hot summer day LOL
*Pushed this back to winter/spring 2024...*
*Innocently whistling as I do the electric slide outta this thread, exit stage right*
MikeQuinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeQuinn Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2024 at 7:01AM
Anyone know if the Hotchkiss 65-67 front and rear sway bars would fit 72-76 Torinos?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2024 at 9:15AM
Front bolts in …rear needed custom brackets and a fair bit of fluffing about…got them in mine…beastly as
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeQuinn Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2024 at 9:48AM
Thanks!!
