  New Posts New Posts RSS Feed - INFO:Poor Man's Temperature Warning Light / Buzzer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Topic: INFO:Poor Man's Temperature Warning Light / Buzzer
    Posted: 20-May-2010 at 3:34AM
Not sure if anyone ever documented this, but I found a temperature sending unit that will close (turn on) around 225 - 240 degrees. Which IMO is perfect to trigger an idiot buzzer that goes off when the car gets too hot.
Bi-Metal Type, Radiator Fan
Switch 3/8 -18Dryseal Thread,
Normally open Closes @ 223 to 239¢K
Ford: E0ZZ-8B607A
Wells: SW501
Standard: TS-121
The 'normal' Ford sending unit for an idiot light has a range of 250 to 260 degrees
Bi-Metal Type, Light Switch
3/8" -18 Dryseal Thread,
Normally open Closes @ 250 to 260 ¢K
Ford: C8GY-10884A, D1FZ-10884A,
D6AZ-10884A, E43Z-10884A
Wells: TU32
Standard: TS36.
These will fit most pushrod V8 Fords, and probably some I4/V6.. Not sure on newer stuff...
and these have a different thread pitch than GM.
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2010 at 12:42PM
The 3/8-18 is what will fit into the water neck fittings if I am not mistaken?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2010 at 2:42PM
This fits in the intake.
