Intake gaskets?-could have sworn |
russosborne
Posted: 05-December-2016 at 8:01PM |
I saw a discussion here somewhere, but when I am looking for it I can't find it.
Anyway, changing the intake on my 351C 2V to an Edelbrock Performer 2V 4 barrel. Engine will stay mostly stock other than this for now. Should I go with the pan style like this https://www.summitracing.com/parts/vri-ms15815/applications/make/ford/year/1972/model/ranchero or this style https://www.summitracing.com/parts/fel-1240/applications/make/ford/year/1972 Ignore the brands for the moment, just grabbed some quick links for comparision. Although I am open to suggestions on what brand to use as well. I do live in Phoenix, AZ, and this will be a daily driver. thanks, Russ |
Torino_Chris
Member Joined: 19-July-2016 Location: Germany Status: Offline Points: 120 |
Hey Russ,
did you get any more info on this yet? Because I'm doing the same thing at the moment and I just bought the non-pan style gaskets before I realized there are other ones as well... |
aquartlow
Senior Member Joined: 19-December-2011 Location: Summerfield, Fl Status: Online Points: 2271 |
I installed a "bath-tub" intake gasket on my 472 for an LPG application(also has blocked heat crossover), really helped with fuel boiling issues in the carb's fuel bowls.
lynchster
Both (the pan and intake gasket set)get used. The "pan" gasket is just to keep oil from getting to the underside of the intake.
Torino_Chris
Alright, I think I'll go with the pan style...I just don't want to risk having to take it all apart again just because the gasket has disintegrated under torquing down.
aquartlow
The real benefit of the pan gasket is heat reduction from blocking the hot oil splash/mist from the bottom of the intake plenum/runners.
Senior Member Joined: 30-July-2010 Location: On The Road Status: Offline Points: 6071 |
the turkey pan will/should come with very thin paper gaskets, i believe the paper gaskets go on the heads then the metal tray under the manifold
the reason i don't like the turkey pan is because it creates a cavity under the manifold where condensation forms or holds moisture and rusts through the turkey pan. the last 2 i took off were perforated through by rust pinholes
