intake |
fordpower
Posted: 03-July-2020 at 10:59AM |
Is there a difference between a 84 truck and my 79 351w.
If you find a HO 351 in a truck around that era it should have a 4bbl. |
fordpower
Add said mid 80 ford truck. Cast iron
will it work casting is54te9425 bb I believe. How you doing. |
If it is a 351 carb intake it will bolt on and work.
fordpower
Now if he will ans his add
Rons73
Member Joined: 22-November-2018 Location: Alberta Status: Offline Points: 146 |
E4TE 9425 BB Mine came off a 85 F150 4x4. 351W, 4bbl, cast iron with 4 hole style carb pad.
Should bolt right on
