  New Posts New Posts RSS Feed - Interchange able parts
imtazzie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imtazzie Quote  Post ReplyReply Direct Link To This Post Topic: Interchange able parts
    Posted: 16-August-2013 at 6:18PM
Okay so as most know i have a 73 GTS that i am working on. I am wondering if there is a book or something that might help with parts that might be interchange able with eaither torino's of other years of mustangs or any other ford parts that might fit. Any such thing exist even
Kenn
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 17-August-2013 at 3:08AM
well i just parted out a Lincoln Mark V and basically it's the same car but with a few small changes here and there to the body, chassis, and electronics. I think the Lincoln Mark 4 is just like the Mark 5.
-Billy Conturo
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 17-August-2013 at 3:46AM
-Steering wheels are shared with other 70's Fords. I have an extra deluxe wheel off a Maverick
-Ignition switches are shared with other 70's Fords
-perhaps steering columns also
-drivetrains of course
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 18-August-2013 at 6:25AM
73 is like 72 in that the 'doghouse' is unique, the complete front fascia, hood, bumper, not sure about the fenders? but they're all one year only... 1973
the dash wiring harness and the cluster are also limited year fit IIRC
I use the Rockauto site to cross reference parts when I think they might be the same. look up the same part for both cars & it'll either the same part numbers or different. every couple years or so Ford changed all the electrical plugs & connections so the switches look the same but won't plug in unless you have the correct pigtail to splice in. also different body lines have different plugs with more or less wires for different stuff
further, 1973 was a transitional year, many parts changed somewhere during the 1972 & 3 production years, like front wheel bearings, spindles, control arms, rear axle bearings & seals, rear control bushings? ... more?
most of the time a 1974+ part will work with the right other parts to support it,
or a 1972 part might be correct by itself. if you ever find yourself looking to rebuild the front suspension, you might want to change the control arms over to 1974+ to avoid any confusion about mid-year changes
as you get to know the car you'll understand more what fits & what doesn't
Edited by Rockatansky - 18-August-2013 at 8:48AM
