john's 74 s&h clone build thread |
Post Reply | Page <1 727374 |
Wow! Just saw this... Glad Johnny is OK.
hogfiddles
Here’s the grill I have.... I guess the plastic has some cracks in it, so that would be out. The surround is pretty good..... I might have better vertical metal trims for in the grille but I’ll have to look. I sent a video to John..... hope it went through. Dave Fox
Between all of us, he should be all set. I have two geills, one is painted rattle can black. With a surround. It too is rattle can black no dwnts.
The other geill has cracks similar to the one pictured above. Its surround it is painted metallic silver with no dents
I so need to get my glasses. Forgive the misspellings
thanks everyone! dave i did get the video but didnt get to watch it thoroughly yet...
just removed the mangled bumper assembly... |
hogfiddles
Ok, glad it went through
hogfiddles
Hopefully getting that, the hood, and the Fender out of the way will make things look a whole lot less drastic.
shanefolsom
Senior Member Joined: 28-April-2006 Location: New Hampshire Status: Offline Points: 624 |
OMG! So glad you are okay John.
There seems to be allot of accidents this year with the older cars :( If anyone can rebuild it, it is you. |
1976 Gran Torino Limited #1
1976 Gran Torino Limited #2 1973 Gran Torino Sport 1969 Roadrunner |
yeah there has been
a shout out to steve m. thanks!!! i got the trim and the NOS emblem today
No problem
Eliteman76
John, I did not see that head on pic before. Wow. Lot harder than I originally thought I figured it was more like Matt Dragon's T bone accident back in 1981.
With that being said... Fron frame clip might be do-able, but I would be really checking things for squareness. I know these were not exactly super tight tolerance vehicles when produced in the 1970's but I would certainly eyeball the frame in a cross pattern using the holes in the frame and check from multiple points. I see no reason to salvage a diamond'ed frame unless it can be fixed with a rosebud torch and frame machine. I could see clipping the entire front section. I am honestly curious on pictures of the A pillars, C pillars, and roof skin, if there are any impact deformation. Stuff I saw on a FB post, did not look like the impact twisted the body tub. It goes without saying, but when you get to the point of inspecting the back half...Make sure you check the rear suspension. See if anything like the lower rear control arms got tweaked. Damaged bushings, etc. Impacts like that can ripple effect down an entire vehicle. See it too many times when I used to pull frames and pull unibody structures. Maybe it's time to find a good used Crown Vic Police interceptor and do a 2003-2012 Front clip upgrade and get those 12.5"-13" front big brakes ;)
Pondering: #99Problems |
hogfiddles
Great post...... I highly suspect John knows all that already, though..... but yep..... always good to remind, cuz it’s so easy to forget obvious stuff, too.
thats the plan!
fwiw i already have the big lincoln 12 discs all the way around
hogfiddles
Well, well, well… Would you look at that —- we all called, too!!!
L O L
mtburger sent me a side marker light... thanks mike! i got it today looks great
mtburger
Senior Member Joined: 24-November-2008 Location: Abington, MA Status: Offline Points: 355 |
You are quite welcome Sir.
Sent out a grill surround today. One stud was snapped. There's a few scratches on it and some slight discoloration which will buff out. If I come across anything else that might help out, I'll let you know.
wow thanks steve!
Glad to help. I know where you're coming from. As someone who has been where you're at, I'm just glad that I can help.
looks like its been a while ( post above says a year ago)... haven't done anything on my car just been busier than a cat covering sh*t lately with doing everyone Else's cars...
but i did message another buddy that does bodywork who offered me the use of his frame machine just need to go check it out then haul my car up there and pull the frame a bit then i can graft on the front section and today another torino guy asked if i had a good rear bumper brace? and he sent a pic showing about a dozen bumper guards (not sure why but i do need a nice pair for the front!!!) since i bought a nice front bumper but the guy accidentally sent a rechromed pair but they were for the rear so this may just be the answer probably do a parts swap like last year another kinda local guy wanted the spindle and brakes from the 73 parts ranchero, then one night i saw he posted a 72 scoop section from a hood messaged him, hey if you want to bring that hood section up i'll just swap you for the brakes you wanted!!! he agreed and did so i'm slowly rounding everything i need to fix my car... |
Compton
Senior Member Joined: 22-April-2017 Location: Auckland Status: Offline Points: 626 |
Good to see some progress though…can’t do a rebuild without parts
72 RS 351
That is good progress, the parts are the hardest part.
Admin Group GTS.org Admin Joined: 06-September-2005 Location: Ontario, Canada Status: Online Points: 5802 |
Glad it's coming along. Make sure you post the parts you still need and hopefully some the forum members can help you out. This car will live on!
Great start. I saw that Steve Casteel was selling off some of his parts stash. He might have some good parts.
