  New Posts New Posts RSS Feed - john's 74 s&h clone build thread
 Post Reply Post Reply Page  <1 6162636465 74>
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2016 at 12:35PM
i hit that local show a couple of miles away today, another trophy again this year! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 04-June-2016 at 1:46PM
Way cool!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-June-2016 at 2:34PM
wow, today seems like christmas Big smile paycheck from work today,check from bob (fordpower) for the manifold i sold, phenolic spacer for my step-brother's new carb and manifold set up, new heavy duty tubular upper a-arms for my s-10 4x4 blazer (for getting parts for you guys at that yard!) Big smile
oh and i finally got my new repop door sticker from marti!!!
 so i promptly applied it Big smileBig smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2016 at 12:11PM
hit another local show today...cha-ching Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2016 at 5:06PM
Way to go! Well deserved...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2016 at 11:51AM
hit another show today... that makes two years in a row at that show, too! Wink
Edited by californiajohnny - 20-April-2017 at 7:17PM
Chris E View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris E Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2016 at 12:01PM
Keep it up and you are going to have to build a trophy room!!! Well done buddy!!!!
Chris E
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2016 at 2:31PM
That's great. Make sure you go next year . Whomever you beat out will just shake their head....." not this guy again "
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2016 at 2:39PM
boy that sounds tempting! i was considering taking the vette next year?
Paul100ca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul100ca Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2016 at 5:57AM
do it....
Nothing stops this train.
gnrlee01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 06-August-2016 at 5:10PM
do you have any pictures of the underside of your hood? i see that the way that you grafted yours is completely different than the other 2 ive seen grafted on here.
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 06-August-2016 at 5:43PM
here's a few pics out in the light (high fog all day)
wiring harness, what wiring harness?Wink
SWEET!!!!!!!!!!!!!!!!!!!!!!!
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 06-August-2016 at 6:42PM
smog, you haven't seen my thread???ShockedShockedShocked
steve, no i don't but i can take a few. i did it different for two reasons...
1) my theory to do the full body line cut was to save any warping across the front in front of the scoop (didn't really matter, BTW)
2) i didn't see the other threads because i did this just about the same time i joined on here, and didn't know that quite a few others had the same idea of adding the scoop, and had already done itConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 07-August-2016 at 6:45AM
i will look forward to seeing how yours looks and was done. did the center front half of your hood match up to the contours of the 74's header panel? the way you did yours, is making me wonder what it is that is so different between the 72 hood contours and the 73-76 hood contours. so far, based on what ive seen in the cut and weld pics, the back contour seams to be the same, and if the front center is the same shape, than i am confused as to what would be so different or hard to just modify a 72 hood to bolt straight onto the newer models.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 1:14PM
Another local show today... another trophy BTW WinkBig smile
Edited by californiajohnny - 20-August-2016 at 6:40PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 2:01PM
can you inform me on the questions ive asked about your hood?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 2:15PM
the front center is not the same shape, and the 72 latch area in the hood is different somehow I never did figure that out
if you were to re-sect the front from the correct year car the rest of the 72 hood should fall into place?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 2:20PM
with that info, i wonder what would be easier and make it look more factory and less noticeable, either re-secting the front like youve mentioned or doing it like the others have done.
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 4:08PM
steve, i just sent you a lengthy pm to explain some of that. i did mine my way because i didn't know any better and had just joined here and wasn't aware that others had done this mod Confused
Uante View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Uante Quote  Post ReplyReply Direct Link To This Post Posted: 20-August-2016 at 4:18PM
I seem to remember that the hood latch configuration on the 72 hood is totally different from the 73 because 73 was the first year of the underdash hood release cable. The 72 hood also has a slightly different shape in the front and tapers differently from the hinge to the front...just enough to make it impossible to align with proper gaping.
'73 Gran Torino Brougham
'63 Econoline Standard Van
- Brent *USAF RET*
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 21-August-2016 at 4:54AM
the taper too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-September-2016 at 3:59PM
night before last... i made a custom plate for the shifter surround and woodgrained it to match the rest of the interior Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 25-September-2016 at 4:50AM
NICE!!! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 3:04PM
it took me the last 5 days to go through and read every post from the first to the last on here, and as much as i wish i wouldve written my questions down on various stages through here, i just got to thinking, with all the chrome, stainless and polished aluminum that the front of your engine has, have you ever considered converting to a serpentine belt system with the bullet tipped looking pulleys? they would look fantastic on this!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 3:09PM
yeah they are pretty pricey for that set up and i think i'd have to swap P/S pumps Confused
right now i'm considering the rear disc/big disc front swap. stay tuned...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote gnrlee01 Quote  Post ReplyReply Direct Link To This Post Posted: 04-October-2016 at 3:20PM
hey, while youre considering that front/rear disk swap...as you are gathering up the parts needed for it, grab a secon set of everything for me while youre at it. i plan on doing the same thing. right now i am doing what i can to gather up all the various different parts, tips and education from all of you guys that i can BEFORE i begin my actual tear down, so that i can get it done relatively quickly, but more importantly, learning from all of you guys' experience, both good and bad...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-October-2016 at 6:50PM
well saturday we went after big disc parts at that yard...out of the 10 or so lincolns there only one had rear discs but the rear end was already gone Angry
so the hunt continues Confused but on a positive note i did get the mastercylinder and correct proportioning valve, as well as a pair of front big caliper brackets Thumbs Up so i got them cleaned up and painted:
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2016 at 6:22AM
Just ordered new 12" rotors for the front from the local parts store they'll be there at 1 o'clock, but i doubt I'll get home early enough to pick them up
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-October-2016 at 6:39PM
well i got to the parts store right at closing! picked the new rotors Big smile well of coarse i had to install them!!! full size brackets installed:
12" lincoln rotor installed, original torino caliper back on, passenger side finished Thumbs Up
 now on to the drivers side...
DONE! Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-October-2016 at 9:15AM
So, are you getting 5x5 wheels?
This page was generated in 0.225 seconds.
