  New Posts New Posts RSS Feed - Latch Pillar Seals
Latch Pillar Seals
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2017 at 3:25AM
I just talked to Dan, he is really busy with his business and that is taking priority. He does not want to venture a guess when he will get back to it.
Marc
German Shepherd Rescue
1967 Ford Fairlane 500, 390
forddude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forddude Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2017 at 3:59AM
-Anyone discover a solution for "Pillar Post Quarter Window" Seals?  still need a pair for my 72 as mine are just the metal bones.
-Not aware of any repops for any years.
-Any success using seals from a later year and trimming?
72 GTS sportsroof, original survivor
72 GTS formal, parted
96 Tbird 4.6, 18k org mi
13 Stang 5.0 6spd
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2017 at 4:34AM
There is a good thread floating around about redoing the latch pillar seals.
Edited by picon3 - 21-December-2017 at 4:37AM
1972 GTS 351CJ-4V black/black
Post Options Post Options   Thanks (0) Thanks(0)   Quote forddude Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2017 at 4:55AM
Ah, thanks. following that post now.  thought id have to do some sort of rubber spray technique to recreate the rubber on mine. or maybe build them up with foam, shape them, then rubber spray to seal them.  "Flex seal" is available in liquid form.
13 Stang 5.0 6spd
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 8:28AM
I am talking to a rubber molding company in NZ here about recreating these seals. Not sure on the cost yet but just gauging interest from members at present...
Have managed to source two set that will be used as donors as they are too brittle to be used on a vehicle
Will definitely be getting a set made for my car but if there is enough interest will consider getting a run done
Will probably be based on the 74-76 seal as a slot for the 72-73 cars can be cut into them easily enough....
Let me know if you're interested and what you'd be prepared to pay so I can see if it's cost effective
Thanks guys
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 3:46PM
yes the important thing is to have the metal in it so it keeps its shape and stays mounted to the body and to get a good intact mold from a set, then rework the mold so that the new ones don't have cracks molded into them from the originalsWink i too was going to work on finding a company to take interest in repopping these as almost everybody needs them!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 3:54PM
Getting the metal reproduced is the easy part and already sorted..trying to get the setup tooling cost for the mold down is going to be more difficult
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 2:55PM
I’m in for a set if you get them made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 5:14PM
greg i'd be interested if they are an exact repop of the originals as well as many many members here and on several facebook sites too i'm sure!
 the main thing would be to make a mold off of a perfect pair with the upper edges still intact, then if there are any cracks they would need to be smoothed and reworked in the final molds, so you have a clean new replicas of them with the metal molded in just like original
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 10:30PM
Greg, put me down for a set as well.... if they are as John noted above.
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2018 at 5:41AM
I would buy a set if they get made .
Jerry VerSchneider
