  New Posts New Posts RSS Feed - Latch Pillar Seals
Latch Pillar Seals
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 10:04AM
On the formals 72-73, when the rear window opens, does it roll down completely or just move back a couple inches like the 72-76 Thunderbirds?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 1:18PM
ilyes?
green 72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote green 72 Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2016 at 3:17PM
On the 72 &73 formal tops they roll down some and then tip back. They do roll all the way out of sight into the quarter.
Dan                             1972 GTS Formal
benzesrule View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote benzesrule Quote  Post ReplyReply Direct Link To This Post Posted: 14-February-2016 at 11:45AM
On my 73 Formal roof they are power and they go straight back.
Phil
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2016 at 1:57PM
Hope these hit the streets soon...
Marc
German Shepherd Rescue
1967 Ford Fairlane 500, 390
forddude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forddude Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 3:13AM
hello,
  has anyone recently heard from the gentlemen or received a pair of his seals?  I dont want to bother him if he's backlogged with inquires.
Of course I could use a pair too and am considering rebuilding mine with some type of silicone or  rubber spray.
Question#2:  cant recall if there is a gasket that goes under the trunk emblem flapper?  yes or no?
Comment#1:   my qtr windows in my 72 do not go all the way down, maybe 2" inches of the window is still viewable when rolled down.
72 GTS sportsroof, original survivor
72 GTS formal, parted
96 Tbird 4.6, 18k org mi
13 Stang 5.0 6spd
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 20-April-2016 at 5:54AM
Originally posted by forddude forddude wrote:
hello,
NO GASKET UNDER FLIPPER.
YOU'LL NEED TO GET IN AND ADJUST THE BOTTOM STOPS FOR THE WINDOW.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2017 at 4:05AM
Anything ever come of this? I was expecting to by some.
Marc
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2017 at 11:59AM
I would buy these too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2017 at 12:48AM
I will try to call him today.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2017 at 3:25AM
I just talked to Dan, he is really busy with his business and that is taking priority. He does not want to venture a guess when he will get back to it.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote forddude Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2017 at 3:59AM
-Anyone discover a solution for "Pillar Post Quarter Window" Seals?  still need a pair for my 72 as mine are just the metal bones.
-Not aware of any repops for any years.
-Any success using seals from a later year and trimming?
13 Stang 5.0 6spd
picon3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote picon3 Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2017 at 4:34AM
There is a good thread floating around about redoing the latch pillar seals.
Edited by picon3 - 21-December-2017 at 4:37AM
1972 GTS 351CJ-4V black/black
Post Options Post Options   Thanks (0) Thanks(0)   Quote forddude Quote  Post ReplyReply Direct Link To This Post Posted: 21-December-2017 at 4:55AM
Ah, thanks. following that post now.  thought id have to do some sort of rubber spray technique to recreate the rubber on mine. or maybe build them up with foam, shape them, then rubber spray to seal them.  "Flex seal" is available in liquid form.
13 Stang 5.0 6spd
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 8:28AM
I am talking to a rubber molding company in NZ here about recreating these seals. Not sure on the cost yet but just gauging interest from members at present...
Have managed to source two set that will be used as donors as they are too brittle to be used on a vehicle
Will definitely be getting a set made for my car but if there is enough interest will consider getting a run done
Will probably be based on the 74-76 seal as a slot for the 72-73 cars can be cut into them easily enough....
Let me know if you're interested and what you'd be prepared to pay so I can see if it's cost effective
Thanks guys
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 3:46PM
yes the important thing is to have the metal in it so it keeps its shape and stays mounted to the body and to get a good intact mold from a set, then rework the mold so that the new ones don't have cracks molded into them from the originalsWink i too was going to work on finding a company to take interest in repopping these as almost everybody needs them!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 3:54PM
Getting the metal reproduced is the easy part and already sorted..trying to get the setup tooling cost for the mold down is going to be more difficult
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 2:55PM
I’m in for a set if you get them made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 5:14PM
greg i'd be interested if they are an exact repop of the originals as well as many many members here and on several facebook sites too i'm sure!
 the main thing would be to make a mold off of a perfect pair with the upper edges still intact, then if there are any cracks they would need to be smoothed and reworked in the final molds, so you have a clean new replicas of them with the metal molded in just like original
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 10:30PM
Greg, put me down for a set as well.... if they are as John noted above.
jversch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jversch Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2018 at 5:41AM
I would buy a set if they get made .
Jerry VerSchneider
Timustbe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timustbe Quote  Post ReplyReply Direct Link To This Post Posted: 22-April-2018 at 1:22PM
Add me to the list of those looking to get a set for my '72 Q Code Sport roof.
Tim Northcutt
'72 Ford Gran Torino Sport (Pearl White)
'07 Jack Roush SC F-150 (red)
'02 HD Road King Classic (Luxury Blue and Diamond Ice)
bdaugette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdaugette Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2018 at 10:31AM
I would also be interested..
Bill Daugette
72 GTS 351C 4V
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2018 at 1:12PM
Have been making a few enquiries with other rubber molding companies but they're all around NZ$2000 (US 1500) for the tooling of the mold...will be putting it on the back burner for a while as there's more important things to do on the car but will let you guys know when proceeding
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2018 at 5:56AM
How much more for the steel inserts, the actual rubber and molding costs??  20 sets presold for $100.00 or 30 set at $75.00 and tooling and material is covered?? I'm sure we could easily do that here on the forum.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2018 at 1:38PM
Manufacturing costs are relatively cheap...about US$25-30 for the rubber injection part and probably around $10 maximum for the steel insert
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-May-2018 at 3:13PM
if the final cost was $75-100 i think a lot could be sold!!! there's what 2k members here 2k on a fb site, 1.5k on another.... that many members most all of them need these seals!!! even if only 1/2 of all those guys bought them, that's a lot Wink yes some wouldn't sell right away but if they were available and the word got out , they would sell!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2018 at 10:46AM
We here in the US will also have to figure the import duties/taxes. How much will those and shipping add to the cost?? Wonder if there is a US member with a business thru which a large lot of the seals could be imported and then shipped to members?
Hmmmm......
Post Options Post Options   Thanks (0) Thanks(0)   Quote TV 2M8O Quote  Post ReplyReply Direct Link To This Post Posted: 13-February-2019 at 5:15AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-February-2019 at 4:16AM
LOOKY HERE.....<div id="UMS_TOOLTIP" style="left: -100000px; top: -100000px; cursor: pointer;">
Wow, someone is actually reproducing the seals - finally. Too bad they won't ship outside the lower 48 though.  These guys claim to be restoring Torinos for almost 20 years, I wonder if they know about our site?
Here's their story and a couple of pics:
Quote
<div id="UMS_TOOLTIP" style="left: -100000px; top: -100000px; cursor: pointer;">We are Gran Torino owners who have been searching for new pillar seals and body plugs to actually fit our car. We own a machine shop and thought why not expand and make a product that we could use on our 1976 Gran Torino, 2 door hardtop and our 1972 Gran Torino sport fastback.  They had old deteriorating pillar seals and body seals. We couldn't find them anywhere.
We have been restoring Gran Torino's for seventeen years and we have never found a decent pair of pillar seals. Now with the introduction of 3D printing we decided to make them for ourselves and make them available to the rest of the  Gran Torino owners. These are not restored seals. These are brand new 3D printed pillar seals. These should fit other 1972 Gran Torino sport fastbacks and 1974-1976 Gran Torino 2 door hardtops.
If there are any other impossible to find parts we would consider 3D printing or machining them if there is enough interest.
Edited by 72FordGTS - 15-February-2019 at 4:21AM
