  New Posts New Posts RSS Feed - Leaded gas
Leaded gas
Rivercrest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Topic: Leaded gas
    Posted: 06-September-2021 at 5:28PM
Anyone have thoughts or suggestions when it comes to using unleaded fuel in a 72 351C. I was able to buy a lead additive but the supplier is no longer making this item. Proper lubrication is the concern........ Thanks
Bob
1974 Cougar XR7 with a 72 351C
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-September-2021 at 7:55AM
lead was to lube the exhaust valve seats, putting in hardened seats will cure that.  running unleaded won't cause damage right away but over a long time eventually the valves can sink at which point you'll need to rebuild the heads and install hardened seats ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 3:13AM
Thanks for that, it's appreciated.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 8:54AM
1972 Ford engines were designed for low lead fuel, so I am not sure of they had the hardened exhaust seats yet. Rockatansky might know. What I do know is that my 1972  400, which uses essentially the same heads as your 351-2V, ran unleaded for decades and to 150,000 miles without any ill effects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 1:40PM
They used a "hardening" process on the heads but no valve seats at the time.
13 Taurus SHO "Mr Pig"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 3:08PM
All good information, thanks again to all who replied.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2021 at 3:29PM
i read somewhere that at some point an induction hardening process was used and those seats tended to crack. consider that the original seats are likely work hardened by now and may last a good long time. also consider that TEL was added as an anti-knock agent, it lubricating and cushioning effect on valves and seats may be an old wives tale?
https://en.wikipedia.org/wiki/Tetraethyllead
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2021 at 10:33AM
Got a moron to put about a dozen deer slugs in his gas tank to "Make up for the lead" back in the day.
(Just the slug, not the shell/powder). He actually pulled them apart and put them in his Monte Carlo's tank. Good Times...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rivercrest Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2021 at 3:09PM
maybe some used leaded fishing weights too......LOL LOL LOL
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 16-September-2021 at 4:12PM
