  New Posts New Posts RSS Feed - LED cluster lights
LED cluster lights
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Topic: LED cluster lights
    Posted: 09-April-2017 at 3:15PM
Has anyone done this? Do they dim using the rheostat on the headlamp switch?
91 F-150
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2017 at 4:08PM
i put red LED's in mine! they don't dim, but IDK my rheostat could be bad??? i had green LED's in my old kenworth and they dimmed but then i had like 30 gauges in it
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2017 at 4:23PM
Did you have to swap over to an electronic flasher because of the signal indicators? I've heard you have to using them for signal lamps but wasn't sure about the dash indicators.
Edited by lynchster - 09-April-2017 at 4:23PM
91 F-150
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2017 at 4:27PM
if you just want it a bit brighter, just spray the inside of the cluster with some silver paint. I have seen this on a chevy truck cluster and it makes a huge difference, plus you can still dim when need be. I'd hate to have a bright led lit dash that I couldn't dim. must be gettin old, but those bright dash lights bother my eyes on a long drive.
Edited by MrSmog - 09-April-2017 at 4:33PM
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2017 at 4:37PM
i think i left the incandescent bulbs in the dash indicators? but i also used LED's in the front and rear turn sig bulbs with an electronic flasher all that works great
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2017 at 4:54PM
here's the brand and part# of the flasher i used and i've bought several for many vehicles, exact fit and replacement! excellent quality!!!
http://www.ebay.com/itm/Keep-It-Clean-FF552NLF-No-Load-Fixed-Flasher-New-/151690703358?hash=item23517871fe
