  New Posts New Posts RSS Feed - Left Turn Signal
Left Turn Signal
JJJTorinoCobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJJTorinoCobra Quote  Post ReplyReply Direct Link To This Post Topic: Left Turn Signal
    Posted: 09-September-2020 at 11:03PM
Hello,
A pleasure to meet ALL of you!
71 Torino Cobra 351 Cleveland
When I turn on the head lights my dash left turn signal light is on solid. I noticed my front side marker lights are not coming on and the rear driver side does not come on. I replaced the bulbs and turn signal fuse and that did not fix the problem. The turn signal works with the headlights off. Does anyone have an idea what I should check?
Respectfully,
Josh
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M. Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2020 at 11:04AM
That sounds like a bad ground (black wire)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-September-2020 at 7:30PM
usually that means a marker light is out on that side but since you now know it's out you'll need to figure out why... check bulbs first then connections, then maybe grounds on that side...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJJTorinoCobra Quote  Post ReplyReply Direct Link To This Post Posted: 11-September-2020 at 1:49PM
Gents,
Thank you!
T boy View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote T boy Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2020 at 3:11PM
Josh,
I have the exact problem, left won’t flash when lights are on.  Did you come up with a fix?
I’m guessing it may be a ground.  Where is the ground on that side?
T-boy
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2020 at 5:54PM
it flashes but not with the lights on? you mean the outside bulb ? or the dash indicator dont flash when the lights are on? that usually indicates a bulb out on that side! but if the outside bulbs dont flash with the lights on... i'd guess a ground issue?
 generally the grounds are on each side near the headlights grounded short to the core support...
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote T boy Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2020 at 3:56AM
Thanks Johnny.  I’ll look at it today and report back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJJTorinoCobra Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2020 at 6:21PM
T boy,
Apologies for the late response! Unfortunately I m out in the field. I should have an answer for you in two weeks when I return home.
I’m praying it will be bad ground to trace. Before asking the question I almost replaced the turn signal switch/ lever.
Respectfully,
Josh
