  New Posts New Posts RSS Feed - lighting issues
lighting issues
The Torino Kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Topic: lighting issues
    Posted: 01-December-2019 at 6:10PM
Hello all, On my way home tonight, my dash lights would go on and off every so often. If i wiggled the headlamp switch they would come back on....also I would hear a "click" coming from under the  dash? Am I looking at a bad headlamp switch or cluster regulator?
 Also my wiper motor is slowing dying, has anyone here rebuilt theirs with success? If so any links to share?
thanks for your time.
1973 Gran Torino Sport CJ 351
'Q' code 63R body
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-December-2019 at 7:24PM
probably the dimming part of the switch??? starting to wear out?
 meaning the rheostat....
Edited by californiajohnny - 03-December-2019 at 1:52PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 01-December-2019 at 7:26PM
cluster regulator just controls the voltage to the gas gauge and such
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 12:01AM
be aware that for a long time now( though I’m not sure if it extends back to our vintages), vehicles are required to be wired so that if the dash is dark, the rear of the car is dark.  It’s a safety thing.  If your headlights go out you’ll notice it, but if your taillight are out your dash goes out too— otherwise you’d not know until either you get pulled over or someone rams you from behind.  I’d first start looking for a new switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 12:09PM
IIRC there's a circuit breaker inside the headlamp switch, it's dying
think about doing a headlamp relay set-up with the new switch,
it'll take load off the switch so it lasts forever and supply higher voltage to the headlamps so they run brighter
https://www.speedwaymotors.com/Headlight-Relay-Harness-Kit,58825.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 12:49PM
that breaker is just for the head lights... had some years ago that the head lights would go off! one day i took a ford switch apart and found that breaker now i know what causes that Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2019 at 3:29PM
thank you for all the advice/info, i ordered a new headlamp and high/low switch as well. Clap
'Q' code 63R body
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 9:27AM
it could be as simple as the rheostat losing contact but the clicking sound suggests a breaker or relay resetting
hopefully your new switches will cure the glitch Thumbs Up
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 4:54PM
Added a relay kit similar to this, stopped my headlights from going out when the internal switch relay would overheat. my dash lights never went out though so I think its probably the dimmer part of the headlight switch.
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2019 at 7:45PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2019 at 4:10PM
thank you. Clap
'Q' code 63R body
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Torino Kid Quote  Post ReplyReply Direct Link To This Post Posted: 04-December-2019 at 4:13PM
Has anyone rebuilt their wiper motor with success?
'Q' code 63R body
