lighting issues |
The Torino Kid ![]() Senior Member ![]() ![]() Joined: 23-November-2003 Location: United States Status: Offline Points: 210 |
![]() ![]() ![]() ![]() ![]() Posted: 01-December-2019 at 6:10PM |
Hello all, On my way home tonight, my dash lights would go on and off every so often. If i wiggled the headlamp switch they would come back on....also I would hear a "click" coming from under the dash? Am I looking at a bad headlamp switch or cluster regulator? Also my wiper motor is slowing dying, has anyone here rebuilt theirs with success? If so any links to share? thanks for your time. |
1973 Gran Torino Sport CJ 351
'Q' code 63R body |
californiajohnny ![]() Senior Member ![]() ![]() Joined: 05-October-2013 Location: winlock, wa Status: Online Points: 11459 |
probably the dimming part of the switch??? starting to wear out?
meaning the rheostat.... Edited by californiajohnny - 03-December-2019 at 1:52PM |
cluster regulator just controls the voltage to the gas gauge and such
hogfiddles ![]() Senior Member ![]() ![]() Joined: 19-September-2016 Location: Central NY Status: Offline Points: 479 |
be aware that for a long time now( though I’m not sure if it extends back to our vintages), vehicles are required to be wired so that if the dash is dark, the rear of the car is dark. It’s a safety thing. If your headlights go out you’ll notice it, but if your taillight are out your dash goes out too— otherwise you’d not know until either you get pulled over or someone rams you from behind. I’d first start looking for a new switch
1969 Torino GT - M code numerous mid-80's Yamaha XJ-Series (5 trophies and counting) |
Rockatansky ![]() Senior Member ![]() Joined: 30-July-2010 Location: On The Road Status: Offline Points: 4695 |
IIRC there's a circuit breaker inside the headlamp switch, it's dying think about doing a headlamp relay set-up with the new switch, it'll take load off the switch so it lasts forever and supply higher voltage to the headlamps so they run brighter
https://www.speedwaymotors.com/Headlight-Relay-Harness-Kit,58825.html |
that breaker is just for the head lights... had some years ago that the head lights would go off! one day i took a ford switch apart and found that breaker now i know what causes that
thank you for all the advice/info, i ordered a new headlamp and high/low switch as well.
'Q' code 63R body |
it could be as simple as the rheostat losing contact but the clicking sound suggests a breaker or relay resetting hopefully your new switches will cure the glitch
madmaxtorino ![]() Moderator Group ![]() ![]() Zombie Killing Training Instructor Joined: 04-August-2010 Location: Lawrenceburg Tn Status: Offline Points: 956 |
Added a relay kit similar to this, stopped my headlights from going out when the internal switch relay would overheat. my dash lights never went out though so I think its probably the dimmer part of the headlight switch.
Allan
thank you.
'Q' code 63R body |
Has anyone rebuilt their wiper motor with success?
'Q' code 63R body |
Tweet
