Limited slip differential |
Post Reply | Page <123 |
"senior citizen" edition
rancheromac
Member Joined: 12-August-2013 Location: IOWA Status: Offline Points: 58 |
clutch packs in this rear end. that's what I put in my 9inch. 3.57 do I need to use a friction modifier in this ? I have only run with the 35m that came with car. I know am putting a 460 swap into thanks for any advice on the eaton
rancheromac
sorry if duplicated. I have this setup , clutch pacs, do I need to use friction modifier? using synthetic gear lube. any other info helpful as I have only run w/351m, know I am doing a built 460. thanks
Thanks(1)
several times i've tried using limited slip type gear lube with the additive already in it, i had to add more additive there just wasn't enough in the store bought oil. Yes clutches need friction modifier
yes,
you can use the trans x brand available at most local parts stores |
rancheromac
I did use castrol synthetic. isn't the friction modifier to reduce foaming?
Thanks(1)
Yes, you still need the friction modifier. It's for the clutches, keeps them from chattering. I got mine from the Ford dealer, it wasn't expensive and it worked great.
rancheromac
how much do you add ? thanks
MrSmog
I always double whats suggested, cheap insurance.
I used one bottle in my rear diff when I changed it last.
rancheromac
that's what I have. 357 gear I think. I put synthetic gear lube castol in. do I need to use a modifier ? thanks
rancheromac
sorry ! I could not see you already replied again so sorry!
marian601
Member Joined: 31-May-2010 Location: poland, europe Status: Offline Points: 62 |
Dear All,
where to buy inexpesive third member with locker, posi trac etc.? I have 28 spline 9". Any additional info needed to choose proper third member?
2015 skoda octavia vRS-wife's car
'99 audi TT quattro 225HP-wife's toy Gran Torino Sport fastback 351C-getting closer :) DUCATI scrambler 803-new toy :) |
Markb73gtorino
Member Joined: 23-September-2018 Location: Corpus Christi Status: Offline Points: 78 |
Speedwaymotors.com
There is a core charge but they have bolt on ready to go 3rd members
fordismyboss
Senior Member Joined: 05-January-2014 Location: SF Bay Area Status: Offline Points: 397 |
I went with an Eaton tru-trac on my 28 spline 9" with 2.75 gears. made a massive difference!
