  New Posts New Posts RSS Feed - Limited slip differential
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 24-December-2018 at 2:03PM
LOL "senior citizen" edition
rancheromac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2019 at 5:18AM
clutch packs in this rear end. that's what I put in my 9inch. 3.57   do I need to use a friction modifier in this ? I have only run with the 35m that came with car. I know am putting a 460 swap into thanks for any advice on the eaton
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2019 at 5:26AM
sorry if duplicated. I have this setup , clutch pacs, do I need to use friction modifier? using synthetic gear lube. any other info helpful as I have only run w/351m, know I am doing a built 460. thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2019 at 6:03AM
several times i've tried using limited slip type gear lube with the additive already in it, i had to add more additive there just wasn't enough in the store bought oil.
Yes clutches need friction modifier
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-January-2019 at 10:47AM
yes,
you can use the trans x brand available at most local parts stores Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 09-January-2019 at 4:05AM
I did use castrol synthetic. isn't the friction modifier to reduce foaming?
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-January-2019 at 1:30PM
Yes, you still need the friction modifier.  It's for the clutches, keeps them from chattering.  I got mine from the Ford dealer, it wasn't expensive and it worked great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rancheromac Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2019 at 6:08AM
how much do you add ? thanks
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2019 at 8:23AM
I always double whats suggested, cheap insurance.
Past 1974 Ranchero GT Q code
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2019 at 12:04PM
I used one bottle in my rear diff when I changed it last.
