Loctite or Black Silicone/RTV - Engine Accessories |
torinomike650
Senior Member Joined: 03-March-2019 Location: Palo Alto, CA Status: Offline Points: 989 |
Posted: 15-March-2019 at 10:21AM |
Hi,
I would like input on which accessory bolts to use Loctite or RTV (or nothing) on: Alternator bolts, bracket bolts, pulley bolts Power steering bolts, bracket bolts, pulley bolts A/C Compressor bolts, bracket bolts, pulley bolts Fan screws Engine mounts Transmission to engine flange bolts Thanks! Mike
1974 Ford Gran Torino |
aquartlow
Senior Member Joined: 19-December-2011 Location: Summerfield, Fl Status: Online Points: 2270 |
If tightened/torqued correctly to spec, you shouldn't need anything. I have never used Lok-tite or RTV on any of those fasteners listed. Certainly not RTV and Lok-tite would give additional protection for a bolt/nut loosening, but would be an absolute PITA if wanting to remove the fasteners.
silicone or any trapped liquid/solid can 'hydraulic' and bust out the casting when you tighten the bolt use the red sparingly! |
torinomike650
thanks for the input, both of you. that link is super helpful!
--Mike
