  New Posts New Posts RSS Feed - Lokar kickdown for C6 / Edelbrock carb
texanrebel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Topic: Lokar kickdown for C6 / Edelbrock carb
    Posted: 07-November-2018 at 10:25PM
Going in a 72 Montego GT - never installed one before, pretty simple straight out of the box or is there other parts etc...that I will need? Thanks everyone!
1972 Montego GT
1977 Mercury Monarch
1988 Ford Thunderbird Turbo Coupe
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-November-2018 at 3:28AM
not sure on the edelbrock? but there is a bracket that goes on a holley to correct the ratio of pull on the cable...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2018 at 2:21PM
I am not familiar with the Edelbrock style carbs. Like John said there is an adaptor for the Holley carbs, so there might be one for an Eddy. When I did my carb swap, I was able to use the factory kickdown rod. They bend easily, so I just tweaked it to work with my new carb. No adapter needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2018 at 5:31AM
OK - thanks for the info....appreciate it.
1972 Montego GT
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2018 at 7:00AM
here's how mine is mounted with the 450 holley that was on my car (running a 600DP now) lokar for an AOD
