  New Posts New Posts RSS Feed - Lokar kickdown for C6 / Edelbrock carb
texanrebel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Topic: Lokar kickdown for C6 / Edelbrock carb
    Posted: 07-November-2018 at 10:25PM
Going in a 72 Montego GT - never installed one before, pretty simple straight out of the box or is there other parts etc...that I will need? Thanks everyone!
1972 Montego GT
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-November-2018 at 3:28AM
not sure on the edelbrock? but there is a bracket that goes on a holley to correct the ratio of pull on the cable...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2018 at 2:21PM
I am not familiar with the Edelbrock style carbs. Like John said there is an adaptor for the Holley carbs, so there might be one for an Eddy. When I did my carb swap, I was able to use the factory kickdown rod. They bend easily, so I just tweaked it to work with my new carb. No adapter needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote texanrebel Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2018 at 5:31AM
OK - thanks for the info....appreciate it.
1972 Montego GT
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2018 at 7:00AM
here's how mine is mounted with the 450 holley that was on my car (running a 600DP now) lokar for an AOD
