  New Posts New Posts RSS Feed - Looking for replacement fron inner wheel wells
Nmjeff View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nmjeff Quote  Post ReplyReply Direct Link To This Post Topic: Looking for replacement fron inner wheel wells
    Posted: 07-September-2020 at 4:08AM
I just purchased a 1978 Cougar XR7 with the Midnight/Chamois trim.  One owner, 61k miles.  Problem is, it has some rusted through front wheel wells.  Anyone with a source to replace them?  I don't just want a liner, if I can get metal replacements.
Please help!
Jeff
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2020 at 1:18PM
welcome! any 72-79 torino, cougar, t-bird ones fit. i have a good drivers side one but most all of the passenger sides are rusted from the batteryConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2020 at 3:33PM
Will powder coat survive battery acid etc? I ask because I have a powder coating place that has a huge oven that can do whole cars etc, so a big inner fender is not hard to have done.
I had some contamination on my 99's fender apron under where the battery was. But from a rollover I hoped it was the battery flipped, and the truck not sold for over a year in a JY'd. I cleaned it up well and painted it all inside and underneath.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-September-2020 at 5:46PM
idk? it's similar to paint just heat melted vs chemical fusion like paint but basically the same underlying materialsConfused i think ceramic coating like on headers is the most durable i've seen so far...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2020 at 12:13AM
I had my fender liners powder coated and so far they have held up well.  Mind you, I don't have a leaky battery and I remove it during storage to ensure that it doesn't leak.  An AGM battery would prevent any leakage and further problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 09-September-2020 at 2:13AM
Thanks. It is nice that these have front end parts that bolt together, to help that kind of care. I coated my radiator support early on when I swapped the 72 front end in 1988. Not having the current access to anything, I chose a bedliner material I found through J.C. Whitney. It worked well then, but I'm not sure how well it has held on.
Today POR15 would be a great choice, or powder coating, or things Eastwood sells for frame and chassis stuff. I used their Rust Encapsulator on my 99 frame instead of POR15, both were new 15 years ago and I went with the Eastwood product. I had discovered their Rust Dissolver before that, called first Oxysolv, that is wonderful for rust treatment. It's liquid like water and weeps into seams, but of course it doesn't eat deep thick rust, only outer porous material.
This page was generated in 0.095 seconds.
