  New Posts New Posts RSS Feed - LTD II Headers
Topic ClosedLTD II Headers
Guests View Drop Down
Guest
Guest
Direct Link To This Post Topic: LTD II Headers
    Posted: 11-December-2003 at 4:42AM
I own a 78 LTD II with a 302 and a C4, and I have looked everywhere for a set of headers for it and found nothing. If anyone has any information on something that would work with it I would appreciate it.
Thanks,
JimW View Drop Down
Direct Link To This Post Posted: 11-December-2003 at 8:19PM
I'd bet you could use the 351W headers in your application... You could check with Hooker or Hedman, but the only difference is a little deck height..  Also, to be perfectly honest, I'd bet you could even use Mustang Shorty headers in a pinch with how much room you have under the hood..
Jim
novaderrik View Drop Down
Direct Link To This Post Posted: 12-December-2003 at 2:49PM
1978 LTD II "S" complete with red over white "Starsky and Hutch" factoy paint. 460/C6 where 351W/C4 used to be
JimW View Drop Down
Direct Link To This Post Posted: 15-December-2003 at 1:58AM
Be careful with those as they seem to somewhat contradict themselves.. (listing all from 66-73) There was a big difference between a 66 fairlane and a 73, not the least being that the 73 was a full frame car, and the 66 was (I believe) a unibody.  On the other hand, it appears Hedman, Hooker and JC Whitney all seem to group those cars, so, if it fits a '73, it should fit yours..  What are you looking to do with the car?
Jim
ponyman89 View Drop Down
Direct Link To This Post Posted: 15-December-2003 at 7:44AM
 I have not tried yet but I am installing a set of factory 87-93 mustang shorty headers in my 79 tbird there is a tonne of room in there and the headers will fit around an aod tranny on a stang and the c 4 is a narrower tranny it's a cheap swap outand the factory shorties from those years work well even up too 300 hp, I don't know about the H pipe off a stang but I will be using similar to that design as the H helps out the power and there is alot of room under your car to put one
1979 thunderbird 302,c4
1974 ranchero 400,c6
