LTD II modification questions |
unlovedford
Posted: 18-December-2015 at 2:16AM |
I may be getting an LTD II Sport and have some questions. Info: car has A/C, 351 Windsor, no power windows, locks or seats. Bench seat interior.
If I get this car, I want to install a set of springs to lower the front and rear down over the wheels a bit. Wheels will be 17 X 8 front and 18 X 9 rear. 235/55-17 front, 255/55-18 rear. Will install a Lares 841 box and HD CVPI shocks. My typical mods on these cars. Will this combo fit under the fenderwells of this car? They will on a Torino, but these have a different body. Any special issues? What springs and how much to cut to achieve the results I want? Front fenders should come halfway down the tire sidewall top, but no further. Rears should be about the same. I will be tucking the bumpers on it, so how will this affect the value? These are not high-dollar cars, and this will be morphed into a somewhat more mean appearance, but I don't want to ruin the value. Appreciate the advice. |
fordpower
Senior Member Joined: 02-September-2010 Location: willseyville,ny Status: Offline Points: 1763 |
The value is nada or nothing I have asked 3200 for mine and had no responses.As for the one you are looking at it has 76 elete front springs for big motor.Rears are moog self leveling I think. Shocks are gab air on rear and monro on front I believe, again for elete.All bushings are poly .etc.
aquartlow
Joe,
Not sure if you remember my '79 Ranchero I drove to Dawsonville, it uses the same front fenders as an LTD II. I previously had 255/50/17's on it(20's were on it at Dawsonville) with 17x8's w/ 4.5" back spacing using MOOG 9012 (Lincoln Mark IV)front springs with 1.5 coils cut off and it never rubbed anywhere. The rear springs had about 1 coil cut off with new pigtails formed. I have pics, but Supermotors.net if FUBAR'd right now for some reason. I can't really recommend what spring or how many coils to cut off due to vehicle differences(obviously). KYB gas-a-justs all the way around.
Edited by aquartlow - 18-December-2015 at 8:05AM |
it could depend a lot on the back spacing! how much clearance on the outer edge of the fender at the tire on the torino? and the same regarding the inside edge of the tire?
i would imagine the inner fender wells are the same, the outer shouldn't be any more than maybe an inch flatter than a torino fender??? just have to try them and see how they fit, have someone turn the steering and watch the tire clearance all the way around lock to lock both sides |
n2fordwagons
Thanks(1)
1st off. Congrats and Good Luck! Hope you get it. I love LTD II's. Maybe try cutting the existing front coils, to see if you can get the desired drop? That's what I did with my LTD II wagon. Otherwise, the only place that I know of to purchase drop springs is Eaton. They'll be $500 shipped, and give you a 2" drop from factory height. That's the most Eaton is willing to drop. Then maybe you can cut some more from there. I recently called around looking for drop springs for my '79 Tbird, and Eaton was the cheapest place I could find, with the biggest advertised drop. Or, maybe some kinda bag system?Otherwise, I'd go with Todd's ideas. He got a huge drop with his Ranchero, using off the shelf springs, that he cut. Before: And Todd's Ranchero: Edited by n2fordwagons - 18-December-2015 at 1:43PM |
Jeff
Dan the ranchero man
Senior Member Joined: 24-July-2011 Location: Mchenry,IL Status: Offline Points: 1173 |
My take on this would be anything that has worked for your torino will work on your LTD II. Both cars sit on the exact same chassis platform. The body will actually give you a little more play room in the back. The same in the front. Having both the 74 and 79 rancheros and doing frame offs on both has taught me this. Hope this helps Take care Dan
fordpower
Here's hoping you can work something out.I also love those ltd2 and would love to see one with bumpers done right.
Wheel wells (flared area) are bigger in the rear than torino, front inner fenders are the same, on the same chassis, so anything that fits torino will work. Rear bumpers are the same as 74-76, but fit the look of the later cars better (designed for big bumpers, not tacked on). Front is just a rework of the Elite clip.
kychevyguy
Good luck on this, I love the deuces. But I thought you were trying to get rid of a bunch to make some room?
JT, USAF Ret./Architect
aquartlow
Here's a few pics'
I have 2 sets of coil springs that have been cut. Both sets are about 14" total length1) Moog 9012, originally were 17.63" tall and the Moog 6446 were 16.73" tall. These only leave around 1" of space between the lower control arm bumper and the upper coil spring "bucket", this is with BB/C6 and all accessories. I actually cut the bumper in half to lower a bit more when I installed the current HD F150 springs(Moog 80100).
jmen22
Brand New Member Joined: 15-February-2016 Location: Tennessee Status: Offline Points: 1 |
n2fordwagons, do you still have this one? An identical twin (or this one if you no longer have it) live just around the corner from me. Small world.. Edited by jmen22 - 01-March-2016 at 4:34PM |
ssregal39
New Member Joined: 04-August-2013 Location: Norfolk VA Status: Offline Points: 27 |
lynchster
I wouldn't concern myself with NADA. They are always going to be niche cars and will be worth what someone is willing to pay for them. On the other hand, none of the changes you propose are irreversible with sockets and wrenches. Have at it!
aquartlow
Sorry not to get back to you sooner. It is just an LTD II hood with a '69 Cougar Eliminator scoop attached, the hood is cut through with a fabricated ram-air/fresh-air ducting. The engine pulls very little to no air from under the hood. |
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
77-79 Ranchero and LTDII are the same front ends.
They also share the same HOOD from the 74-76 Elite. the fender flare is the same on the all the cars except the 72's with the lower front edge. Tires and rims on the front fit the same on all our models. Rear is where the Torino is different, the Torino has a straight side rear quarter where all the others have a much wider flared wheel well. The same rims and tires that were getting DESTROYED on the Torino, barely touch on the Elite!
Owner- www.CaNDeCustoms.com |
