  New Posts New Posts RSS Feed - ltd11
ltd11
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: ltd11
    Posted: 14-June-2016 at 12:26AM
How do you remove the coat hanger thing from side panel. I don't want to break it.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 1:31AM
Use a thin small flat head screwdriver and start to pry it off from the bottom of the hangar and slip the vinyl cover off the plastic retainer that is underneath. It slips off the plastic housing going towards the top. The vinyl hangar cover is thin so be careful not to puncture the headliner. Work it off gently as the plastic may be brittle and lift it up off the top.
Edited by dave302 - 14-June-2016 at 1:35AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 1:32AM
When you remove the cover, there is a plastic retainer underneath it, the retainer is held onto the car roof with one screw. There is a picture below of the retainer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 3:28AM
Got it ,though it might just be a clip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 12:35PM
Be careful prying, as your screwdriver will want to slip off and spear your headliner. This is something I really wish I didn't know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 12:53PM
Got it but that was a fear. Is it possible to remove head liner safely.This one is in such good shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 1:02PM
Yes, you can remove the whole headliner safely, but you might have to remove the rear windshield as well. Because the rear windshield might hold the rear portion of the headliner in place.
Edited by dave302 - 14-June-2016 at 11:22PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 1:14PM
Notice in the picture below how the 72-76 headliner wraps underneath the lip of the rear windshield. I do not know if the 77-79 headliners are the same.
Edited by dave302 - 14-June-2016 at 11:26PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 1:15PM
This is a close-up picture of the 72-76 headliner wrapped underneath the lip of the rear windshield.
Edited by dave302 - 14-June-2016 at 11:24PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 1:50PM
Do the later car still wrap under the glass? I thought it was only the gasketed windows (72-76)...
(And WHY the F@#%!!! would you put something porous UNDER the seal that keeps the rain out... I mean... I heard everyone was on dope in the 70s... But SERIOUSLY... What were they THINKING!!!!)
Rant over. We will now return to your regularly scheduled programming.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 2:59PM
The pinto did that on the front window.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 11:19PM
I do not know if the 77-79 headliners also wrap underneath the rear lip of the rear windshield too. Maybe the 77-79 headliner is secured to the rear of the roof with a piece of trim or adhesive? Maybe you do not have to remove the rear windshield on the 77-79.
Edited by dave302 - 14-June-2016 at 11:28PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2016 at 8:55AM
I do not know about an LTD II's headliner, but my Ranchero's was wrapped around the window frame as the above pictures shown(maybe not as bad). I made my own headliner form-fit panel out of 3/16" insulating board and applied the newer style foam backed headliner material. I will say this is done A LOT easier in a Ranchero than an LTD II.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2016 at 9:45AM
I don't need one just the one in the parts car looks so good.Though I could save it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 15-June-2016 at 10:34AM
Give it a shot...
It's in a parts car.
It's good practice in case you ever need to take yours out.
NwOh_Starsky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2016 at 5:55AM
sent you a pm about this
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2016 at 6:51AM
I checked rear it is not wrapped around window seam. Is there a secret on getting it undone glued .
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 16-June-2016 at 9:22AM
That glue has been there a LONG time, I doubt a heat gun will help, possibly brake cleaner/acetone on a rag will help loosen the glue. Probably best would be to rip as much of the headliner off the window frame and just remove what's left with the cleaner/acetone. Good luck.
Edited by aquartlow - 16-June-2016 at 9:23AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2016 at 6:11AM
well I can report you do not have to remove windshield or back window on ltdll now how it comes loose from the sides?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 17-June-2016 at 1:16PM
Sail panels on inside of C-pillars, seat belt mounts, and side roof moldings come off, it should attach with clips and glue under the molding and then you can pop the support rods loose from the ends and the ceiling. the wire rods come down with the headliner, they run thru little sewn tubes/pockets in the headliner and snap into the roof.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2016 at 12:23AM
beginning to think someone put this int in this car. Hole on floor looks like it was cut with a torch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2016 at 4:54AM
what you mean the natural rusting process of our floor pans wasn't enough so someone torched a hole? some people's kids i tell ya Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2016 at 5:51AM
I meant were the shiftier goes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2016 at 6:36AM
Every one I've taken apart or seen taken apart looked like Freddy Kruger was learning to use a plasma cutter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2016 at 1:25PM
That explains it,Why the big cover, seems something simpler would work then you could use reg carpet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-June-2016 at 2:17PM
oh Embarrassed
