  New Posts New Posts RSS Feed - "Major Redmond" / lynchster
 Post Reply Post Reply Page  <1 151617
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 17-January-2018 at 6:58PM
comparing free length progressive to std rate is like apples to watermelons, even if the wire diameter is identical you can't begin to guess what'll happen with load on them. unfortunately even the mfg'r data is usually way off as far as ride height goes
This is true. The car is also minus a lot of weight at this point as well. I can say however that after installing the spring on the driver side, the left side tire sits higher off of the ground at this point.
It was also easier installing the new shorter spring. The taller spring had to be "helped" into place where the shorter on had to be held in place until the rear was jacked up. The shocks were actually topped out with the taller springs. Tightening the shocks down actually lowered the car.
91 F-150
