  New Posts New Posts RSS Feed - Merc Cyclone Now Ford Fairlane
 Post Reply Post Reply Page  <1234 10>
RAPTOR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RAPTOR Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 2:56AM
Great find !!!
1972 Torino Sport 4Spd Q 351c
2010 Ford SVT Raptor
2003 H2 Hummer
1977 CB 750 Cafe Racer
foote500 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 4:17AM
So what am I looking for? If I go back and look at that engine in the F-150, what are the "tells" to look for?
Marc
German Shepherd Rescue
1972 GTS "The Gray Ghost"
1967 Ford Fairlane 500
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2013 at 11:08AM
I have built a bunch of Bumpside ('67-'72) trucks and have found that a lot of supposed FE 390 truck engines are actually 352's. 360's were extremely common then as well for replacement engines. The combinations of FE displacements can range from a 332 to a 428. There are several overlaps that use the same bore and different strokes to acheive the desired displacement. On top of that, certain early 390 engines had the 352 ID on the block for some unknown reason.
If you wanted to look for a better engine that would be stronger, look for an FT version. FE stood for Ford-Edsel, FT stood for Ford Truck. Dimensions are identical, but the FT engines used steel cranks (v/s nodular iron), larger crank snouts, better mix of iron in the block/heads, heavier duty distributors, etc. Since you are rebuilding one anyhow, I would search for the FT block & crank, use the correct Cyclone heads/upper components and have a stronger bottom end.
Just my $0.02
I like the sound of this, will keep that in mind.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2013 at 3:05PM
I have found a local guy who is parting out a 69 Thunderbird with a 429, would this motor fit in my engine bay?
Marc
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 14-October-2013 at 3:44PM
I think it will.
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 15-October-2013 at 1:09PM
That would be radical!
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2013 at 10:18AM
I am stupid, going to look at another wreck tomorrow-1961 Ford Starliner...
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2013 at 12:31PM
is that the one with the retractable hard top?
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2013 at 3:06PM
Hardtop, looks like this:
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 23-December-2013 at 4:35PM
not the car is was thinking of, but cool though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2014 at 6:38AM
No movement on either this car or the GTS, the GTS keeps waiting for the paint booth to come available. But, in the meantime, my dry rotted tires on this were bugging me so I got new tires for it.
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2014 at 8:52AM
Some goodies; more to come such as exhaust manifold, date code correct block .40 over and bell housing.
Marc
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2014 at 11:24AM
Sticking with the 390, I see...  Looking good!!
Jeff
79 Ford Thunderbird w/ T-tops
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2014 at 11:52AM
Well, I think the 351 works good, I may just collect the parts for the 390 and drive the 351 till it is time to rebuild. Then the 390 is ready to drop in.
Plus, the guy who has all the hard to find parts wants to move to Tenn in about three years, so I have between now and then to buy parts.
Like today I just barely mentioned the exhaust manifolds-which are like hens teeth-so he whips a pair out... He has probably multiples of anything a Ford guy wants.
Edited by foote500 - 16-November-2014 at 11:55AM
Marc
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72 RS 351 Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2014 at 1:34PM
Ask him for some 427 heads, the SOHC heads. Two would be just the ticket, ... and maybe the dual four barrel intake if he has at least one of those. Wink
73 Ranchero with a 72 Sport front end, parked since 1990
91 Lincoln Mark VII SE, OBDII 347/4R70W
98 Mercury Mountaineer
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2014 at 6:33PM
^^^ yeah, X2 on that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote foote500 Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2014 at 8:45AM
Just got another 4300 D, going on the cyclone until the 390 gets rebuilt. Going to send it to Allstate carb for resto first.
Marc
freechero View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote freechero Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2014 at 3:19PM
I thought the 4300s were squarebore, and the 4350s were spreadbore?  I have a 1970 429 4300 sitting in the shop right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote freechero Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2014 at 3:24PM
Just my $0.02
Keep in mind, you will have to use the FT balancer, due to the larger snout diameter.  Best way I know to tell a 352 from a 390 is the flange on the back of the crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote freechero Quote  Post ReplyReply Direct Link To This Post Posted: 18-December-2014 at 3:29PM
FYI, a Holley elec choke housing is a bolt up, in place of the OE choke.  I ran one for years on my 429 4300.
