  New Posts New Posts RSS Feed - mirror
mirror
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: mirror
    Posted: 12-September-2019 at 12:10PM
Right side mirror loose, Before I break something is it fixable. I am talking about the glass.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 12-September-2019 at 2:05PM
What type of mirror?  The sport mirrors can be disassembled and all the fasteners, including the ones that hold the glass can be tighten up.  I am not sure about the chrome mirrors though, someone else will have to chime in on those.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2019 at 1:57AM
sports type.any one on here done it.
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2019 at 2:04AM
if you angel the mirror all the way in you will see (with a flashlight) a small Philips head screw... just tighten it up
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2019 at 6:04AM
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-September-2019 at 11:58AM
yes and if the base is loose... there's 2 screws up inside the base holding the mirror housing Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 15-September-2019 at 3:28PM
…And up here in the snow belt, all those steel screws that thread into die-cast aluminum strip out or snap before turning. Get a GOOD screwdriver. No Stanley, no home depot specials, no harbor freight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-September-2019 at 6:06PM
yes^^^
