MSD 6AL where do I put it |
tommy
Member Joined: 04-February-2018 Location: QLD » Fraser Co Status: Offline Points: 44 |
Posted: 13-May-2019 at 8:43PM |
Hi all
finally getting some time to work on the 72 Torino (351c)so first bit of fun is new MSD dist and 6AL unit before i start drilling holes im hoping someone can tell me the best spot to mount the 6AL thanks Dave
72GTS351CJ
I put mine on the side of the battery between the fender and battery. There is a pic on my project thread. I cant seem to post a pic. Maybe something changed. I haven't been around in a bit. -Rick-
72GTS Clint Eastwood Special
torinomike650
Senior Member Joined: 03-March-2019 Location: Palo Alto, CA Status: Offline Points: 989 |
That's odd, my old Motorola ignition box was mounted on the driver side (opposite from battery) near the windshield washer reservoir.
I also purchased the MSD 6AL and mounting kit. Was planning on mounting mine in the same place as the old box unless someone has other recommendations? Which location was stock mounting point for these? -Mike
1974 Ford Gran Torino |
72GTS351CJ
I was also looking for a factory look that's why I chose to hide the box
mean steve
New Member Joined: 23-April-2019 Location: Austin Status: Offline Points: 39 |
I mounted mine virticaly to the core support behind the pass inside headlight.
torinomike650
For me, the stock location is more important than worrying someone walking up at a car show and seeing "MSD" on the box lol!
I also got the black one instead of the red, so it wouldn't stand out as much. Can anyone confirm that the stock location is mounted on the driver side frame?
72GTS351CJ
Are you guys talking about a 72 model? I never seen the battery mounted on the drivers side and also a Motorola box? I didn't think that was available in 72. Just askin
You are right Rick. There was no ignition control boxes on 1972 Torinos. The first Torinos to use the electronic ignitions were the 1974 models (400,460 powered cars and CA emission cars). They used Ford solid state ignition which was similar to the Dura Spark system. All '75-76 cars used Solid State Ignition too, and which mean they would have the externally mounted module.
torinomike650
Mine is 1976. Battery is mounted in front on passenger side. Motorola ignition box is mounted in front on frame, driver side. No idea if that location or the box itself is stock. So wanted to see if someone can confirm that is, in fact, the stock location.
n2fordwagons
Yes, it sounds like yours is at the stock location. It should be on the driver's side. I thought mine was mounted low on the inner fender, I can look when I get home. If I had to guess, you have an OEM style replacement made by Motorola. Here's how it should look: |
Jeff
torinomike650
Yes that's pretty much how it looks. Although I'm guessing the MSD box has different connectors and specific instructions for Ford application? I'll have to make sure I have everything I need before mounting it.
Motorola was making transistorized ignition systems as early as 1965 or before, it's a collectors item and will probably outlast 5 msd's |
tommy
thanks all ive put it on top of the wheel arch driver side its the black series MSD 6AL (got the black pro billet dizzy to go with it)but not hiding it im going resto mod want to get rid of as much as the old sh*t as i can afford so i can drive it without breaking down every time love this car!!!!
maybe the first time i've heard of using MSD equipment for reliability, |
tommy
ran the same set up on my mach 1 393 500 plus hp never let me down Ice is a lot dearer here in Oz actually heaps more expensive here ship loads
