  New Posts New Posts RSS Feed - Need help--Overheating after 5 miles!!!!
79Cougar302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Cougar302 Quote  Post ReplyReply Direct Link To This Post Topic: Need help--Overheating after 5 miles!!!!
    Posted: 05-February-2007 at 4:25AM
HI ---all    I just got a 79 Cougar with 302.
It is also overheating after about 5 miles....I checked the radiator-- I got good flow.....it maybe low on oil......can't check it ......
Where is the engine oil dip stick location??????
I looked all over---I think it is possible missing..............
....plus little water coming out of the muffler.......it could be a head gasket problem??????  Will that cause the over heating????
Thanks for your reply!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 05-February-2007 at 5:19AM
Some questions..
1. How do you know you have "good flow"?
2. Dipstick is in the timing cover, front of the distributor on a 302, IIRC.
3. A little water is normal on startup.
Dumb but necessary questions.
Radiator clear in front?
Does it overheat if sitting still?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Cougar302 Quote  Post ReplyReply Direct Link To This Post Posted: 05-February-2007 at 9:41AM
Thanks 75!
I don't know i have good flow ---the top on the radiator is getting hot water is what a meant.
Radiator is clear but I will double check....
Someone suggests it must be the thermostat...
Do you think it could be the problem??
It could I guess be very low on oil........I will search for the dipstick again........
Thanks in advance...........
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 05-February-2007 at 11:00AM
It could very well be the thermostat.
When it's idling, from a cold start, feel the top hose.. it should start out cold, then all of a sudden become very warm.
You may even notice it on the temp gauge.. slowly increasing, until it hits a certain point... then it'll have a slight drop.. and stay steady.
