  New Posts New Posts RSS Feed - New Daily 1987 Crown Vic with 95 Cobra driveline.
72sport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Topic: New Daily 1987 Crown Vic with 95 Cobra driveline.
    Posted: 09-April-2018 at 11:34AM
I bought an interesting( at least to me) daily driver for the summer.  Story behind the car was the guy totaled his 95 cobra.  He was given the Crown Vic so he decided to swap the driveline into it.  I'm not sure I believe that, but it does have GT40 3 bar heads, T5 Trans, BBK Shorty headers, Mass Air Conversion, I think Explorer intake(he called it a cobra intake), and 3.55 trac lok rearend.
It seems like it should be quicker than it is, but I guess it probably weighs over 4000lbs.
Edited by 72sport - 09-April-2018 at 11:39AM
Tom
1972 Gran Torino Sport 4Spd
MrSmog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2018 at 12:15PM
I like it!
Past 1974 Ranchero GT Q code
torino335 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torino335 Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2018 at 1:11PM
i like it too.it might be set up for top end speed,4000-6000 rpm,my 09 crown vic p71 has the 4.6 with no limiter in it,3.27 gears doesnt shift into overdrive till 130 then its game on lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2018 at 2:42PM
I think it's very nice. I had an '88 Grand Marquis for a daily driver some years ago. It was a great car but it definitely could have used more power.
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 1:09AM
Sleeper mode...ENGAGE! Thumbs Up
John
79 Thunderbird Heritage
79 Thunderbird Town Landau
02 Ram 1500 Sport Quad Cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 1:42AM
Nice! I bet it's fun rowing the gears in a car like that
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 8:59AM
It is a blast to bang gears in a big car, but the car is far from fast. Maybe a little on the quick side, but that is about it. It does have old school glass packs on it too.  It's pretty quiet at idle , but barks when you get on it.  Its fun leaving a light a little hard and watching people looking around to see what is making the noise and then seeing them realizing it is the crown Stick.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 9:02AM
I'm torn on the wire wheel covers.  I do have some white walls to put on the rear, because the white wall/ black wall mix bothers me. I'm not sure if I should do that or have the front tires turned around to black walls and ditch the hubcaps all together.  Whats your opinion?
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 10:09AM
bare wheels will scream punk in a free car, blow the stealth factor
are all 4 tires good, same size, which set will need replacing 1st?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72sport Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 11:11AM
All the tires are in pretty good shape.  I have a pair of white walls that are already mounted and balanced from a parts car. So no cost to have 4 white walls.  They have a 2009 build date, but they are probably not much older than the tires on the car and have excellent tread.
Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 12:53PM
It's your car, but if it were mine, I'd ditch the wire wheels for sure. I'd go more for the cop car look, dog dish caps with black walls.
This is the look I wanted to do with my old Grand Marquis (it was black too).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2018 at 2:19PM
Men In Black hardtop with service edition nut covers works for sure :D
but the Beige Brougham vinyl kinda blows the LE look, it's got the No Threat Here vibe going on
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2018 at 1:35AM
That's awesome.  Love it.
I'd probably rock the whitewalls and spoke hubcaps, myself, for the ultimate sleeper.  Although, I think I'd go for some wider wheels and tires.
Jeff
76 Mercury Montego MX Villager w/ 460 (SOLD)
79 Ford Thunderbird w/ T-tops
69 Ford Country Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrSmog Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2018 at 4:29AM
I'd think that car would run in the 14's in the 1/4 at the drag strip, thats pretty quick. if it's not in that range or seat of the pants "scat", then i'd suspect that it wasn't a cobra motor but maybe the original 5.0 with a v8 explorer (gt-40) top end. if the later is the case, it might be down a little on compression and cam then the cobra motor and might explain why its not as peppy as it should be. I think the cobra motors were like 240 hp and i hear a lot of claims that was a underated number, so who knows? does it seem like it has 3.55 gears in it? might want to check that out. Just seems like it should be quicker then what you say, of course "fast" is a personal thing. still cool as hell IMO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2018 at 6:04AM
The intake isn't '95 cobra, as those intakes had a elbow cast into the area where your throttle body is now, to sweep around the SN-95 shock towers.  It also has the TB on the other side, and flipping it around would poke it into your master cylinder.Big smile  Still a great combo.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2018 at 12:27PM
Yeah, I guess that's true but I really don't like wire wheel covers. But I still think Dog dishes are an improvement even with other colours.  Look at this Crown Vic in a classic Grandma shade:
Before:
After
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2018 at 1:54PM
definitely different but gives me a Field Car vibe now, stealth is out the window
i had an 87 Caprice Brougham with the spoked covers, not my choice but they fit the combo. it would've been too much work involved to de-bro it and no interest on my part anyway, i just left it in Blend Mode
i hope the MiB car has the Red button?
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 4:39PM
That is an awesome combo. If I had kept the '02 Grand Marquis I owned, I was going to convert it to a 5 speed. That should be a keeper for you. Personally, I think a set of 15 X 8 steelies painted body color with the FMC poverty caps would look killer. Maybe even a set of CVPI 16 inchers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-April-2018 at 8:21AM
i have a set of the period correct Turbines but Merc centers. they look better in the pics than in person,
they'd need refinishing for anything above transportation grade but the price is right LOL
Edited by Rockatansky - 13-April-2018 at 8:22AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 14-April-2018 at 2:57AM
Always liked those Turbines. Iconic, like the Magnums.
Matt
1972 Montego MX
1994 F-150 5.8
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2018 at 3:42AM
I like them as well, but I've become too lazy to get down and clean every space between each rib on them, lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2018 at 11:14AM
Yep. Had similiar type wheels long ago, and a real PITA.
Matt
1972 Montego MX
1994 F-150 5.8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 15-April-2018 at 3:05PM
Keep the wire caps, get some 15x8 wheels and 235/70 tires, Police suspension. Go have fun.
