New Exhaust Systems |
Post Reply | Page 12> |
smitty-1976
Member Joined: 02-October-2009 Location: Kansas Status: Offline Points: 96 |
Posted: 09-June-2011 at 9:26AM |
All I found the attached website for Waldron's Exhaust that has replacement exhaust systems for Torinos & Fairlanes in 16GA 409 stainless steel with mufflers. They don't state that they are mandrell bends but they can upsize to 2- 1/2". Has anyone used these guys and if so what was your experience with the product quality and fit? |
JimW
Senior Member Joined: 09-December-2003 Location: USA Status: Offline Points: 602 |
Image on the site is not mandrel bent pipe. If that is accurate to the real system, and they try to crush bend 2.5" stainless pipe to factory bend card, it will be smashed pretty good at the turn behind the muffler and over the axle.. I'd say convenient way to get stainless duals if you don't care about performance, nice to have the option, should fit ok, but upsizing won't do much except probably increase cost..
Just my thoughts, no experience with the company or the product.
Jim
1976 S&H Gran Torino
460/C6/4.33 13.05@105.6 545/C6/3.56 11.52@117.8 More to come!!!! 463rwhp/495rwtq two tons of fun see it and hear it at: www.torinocobra.com www.st |
Guests
Guest |
Personally for classic car exhaust I find it better to find a quality exhaust shop that has a mandrel bender and does custom exhaust cause they can custom bend the pipes to fit under the vehicle and keep it tucked up nice and neat.Pretty much what it cost to buy and ship a prefabbed exhaust system you can get done for a simular price at a exhaust shop and you can check the fit before paying the bill and make sure they run the pipes and mufflers the way you want.I wouldn't trust a prefabbed exhaust on are Torino's ,especially if you use headers cause different brand headers will have the collectors fall in different positions and can have issues with trans crossmember which may require a bend in the pipe for clearence so you don't get an exhaust rattle. I also stay away from something extremely cheap cause quality isn't cheap
Psquare75
Waldron does excellent work, but again, it's not mandrel bent.
As stated, either a shop, a U Fit Kit, or possibly* that 73-77 GM kit. * Hasn't been tried.
SPLUHAR
Member Joined: 02-January-2006 Location: United States Status: Offline Points: 146 |
I just bought these. They look like they'll fit pretty good. |
1976 ELITE, 71 429 w/cam, quadrajet, 4 wheel Mark V disc brakes, 3.25 trac lok, gutted & 12.9'd Mustang steering box
Psquare75
Huh, I didn't even know they made those. When can we expect install pics/details?
Eliteman76
I know on the flowmaster 2.5 U fit I did, I have no complaints, but the rear, over axle area is a pain in the ass.
SPL, would be killer to see some fitment pics, those pipes look damn close to what I had to fab up with the u fit kit.
Pondering: #99Problems |
SPLUHAR
They won't be installed for a few (or more) weeks. Temp'd in driver's side (can't do passenger side because stock single 2" is still there):
Psquare75
Watching with interest!
Eliteman76
Hmm. Looks like very good fitment.
SPLUHAR
These are the pic's that I stared at for a long time before making the decision to buy:
Psquare75
Hey those look familiar! lol.
Psquare75
These pipes ever go in?
SPLUHAR
Building custom headers right now. On lunch break. Weeks in on drivers side already. Passenger side barely started. Long tube equal length try y w/ stick shift. eeeeeeesh.
exhaust to follow. Edited by SPLUHAR - 16-November-2011 at 10:52AM |
Psquare75
Do they look like they'll work with center out mufflers? Can't tell from your picture.
SPLUHAR
Layed them out in the driveway today. They're very close to working perfectly. I may have to tweak the drivers side muff just a little (portion of pipe in front of axle is on a slight angle, towards center of car going forward, causing rear of pipe to point inward out the back. It's probably due to mfg it off slightly). I measured across - 51" @ last bend, w/ std summit 3" x pipe un-cut, and flowmaster 3"-2 1/2" cones. Mufflers are summit turbo offset in center out (reverseable). X pipe is set so that front of it fits nicely in the crossmember. I also measured center of tail exit to center of tail exit on car is about 51" also. Again, this is un-tweaked, un clamped laying on the ground. Exhaust installation will be sometime in december hopefully.
Edited by SPLUHAR - 17-November-2011 at 6:36AM |
TV 2M8O
Senior Member Joined: 20-September-2006 Location: Southern Ohio Status: Offline Points: 2052 |
What's the latest on your exhaust?
smitty-1976
I have it installed and fits perfect. I have no complaints about their products at all and would recommend them to anyone.
TV 2M8O
SPLUHAR, how's your system coming along???
aquartlow
SPLHUAR, I'm very interested also in this tailpipe application as well, if you were able to get them finished, how'd they turn out?FWIW, if anyone wants to go this route, Discountexhaustsystems.com have the same Flowmaster tailpipe kit #15817 for only $99.22! I purchase some 3" Dynomax Ultraflo's about a month ago for $49.43 ea. Good prices and fast shipping. Todd
Edited by aquartlow - 28-March-2012 at 11:46PM |
SPLUHAR
1/2 way done w/ passenger side header, driver's side is (finally) done. Then 400/c6 out, 429/ Galaxie toploader 3 speed in (including building a clutch pedal and zbar, etc). Then exhaust.I work full time days 8-5, mon-fri, plus four 10pm-7am shifts per week at walmart. Time and sleep are at a premium. All work is done on lunch break (1/2hr-45mins at a time). Looking at the drivers-side pipe closer, it's 2 pieces of pipe welded just behind the axle. I'll probably need to grind that weld out and re-aim the back portion of the tail pipe several degrees. Idk if it's a quality issue or a a-g body issue. Passenger side is way closer to working as is, but won't know if it's close enough to work for a while.
btw, still need to cut out/weld in that roof section that I bought from you several years ago psquare
SPLUHAR
Driver's side header:
started with these (1 pair of each) Got both sets off of ebay, $20 for the 5111's (picked them up locally) and $5 (plus shipping) for the 12560's. cut them all up, started w/ the flowtech flanges and started adding pieces, one tac at a time. pics of passenger side to follow soon Edited by SPLUHAR - 29-March-2012 at 4:41AM |
SPLUHAR
1 month worth of work on passenger side:
Edited by SPLUHAR - 29-March-2012 at 6:18AM |
Psquare75
No worries. My cougar was, until a few weeks ago, parked in the very spot you saw it last.
SPLUHAR
Wow! It looked ready to go then!
Psquare75
could never get a handle on the brake issue.. Undrivable because of it. Between that, running hot, alignment issues, exhaust issues... I put exactly 30 miles on it since you've seen it.
then bought the gray Cougar..... then got my truck back together....... then bought a house....... then......then.......
I stuffed it at my parents house for now. Maybe I'll start it this summer. Edited by Psquare75 - 29-March-2012 at 7:32AM |
SPLUHAR
That sucks. Too many projects? I did the Mark V brakes on mine. Fronts first, ran around w/ non matching wheels for a while till the rear blew (always leaked alot, I got tired of putting more oil in it after 4 years). They work somewhere between pretty good and very good. Much better than the origional 10 1/2" fronts and drum rears, almost as good as my wife's car (2009 Kia Borrego). That thing'll stand on its nose when you get on them hard! Ill probably upgrade to a dual diaphragm booster soon (my single leaks in the winter). My car's been overheating since I got it so I know how you feel. Especially on the highway. Tried alot of different things but never cured it. It pissed water out often. The head gasket went last summer, and I think I cracked it putting water in it, hot (i never liked the 400 anyway. Thirsty dog). I found out recently that they don't like to be overbored, and this one was rebuilt at some time. When the 429 goes in, so does an F250 aluminum 2-row (about 2" thick) radiator, and soon after (like in 2 years?) I'll be adding a Ford Windstar dual electric fan and a Taurus alternator. Front end (while it's down) is getting new lower ball joints, s10 blazer springs, dirt track bilstein shocks, and some geometry revisions. Rear is getting matching bilsteins, and im going to cut the lower control arm brackets off of the old rear and weld them to the new one, extending them down about 2" (free-ish south-side machine mod). I always do my own alignments.
Psquare75
Yeah, pretty much. Truth be told, we had that hurricane blow through here last fall. I left it outside, figuring it'd solve my problems one way or another. Pedal is SUPER DUPER sensitive and soft, where if I tap it, the fronts lock and the rears are just sort of along for the ride. I can only stand so much brake fluid and swap so many masters, calipers, prop valves and hard lines from good working systems before I say I quit. That's where I stopped in 2009. Whenever a buddy mechanic/SAE guy comes down, it always ends with "man, that's weird". and still non driveable. Already spent $200 on one of those guys. I need a real shop.
Truck is getting sent out this April for a vibration I can't track down. There goes my tax return, and any fun money I had for the white Cougar. I've had it since 2005, and it's been registered since 2006. maybe 200 miles, total. Depending how the truck goes at this custom shop, the Cougar may go there to finish it off. I'm just tired of looking at yard ornaments. Of course, the gray 77 I own is just a great daily driver, and I think it laughs at me whenever I use it and drive by my parents place. Hindsight what it is 6 years later , I wish I just bought this and never bothered with the other car at all. It's just a money pit, and a nice garage ornament that my friends and I talk about. Oh well. Sorry for the angry thread jack.
SPLUHAR
did you ever change the master cylinder & distribution block to the Lincoln Mark V?
SPLUHAR
http://www.corner-carvers.com/forums/showthread.php?t=43435&highlight=brakes+lock
there's a link to a proportioning valve calculator that may help (post6) Edited by SPLUHAR - 29-March-2012 at 9:48AM |
