  New Posts New Posts RSS Feed - New guy
New guy
GranPeppers73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranPeppers73 Quote  Post ReplyReply Direct Link To This Post Topic: New guy
    Posted: 08-February-2019 at 5:19AM
73 gran torino sport. Wondering if I can use the wire hsrness out of my 94 crown vic and put it in my 73 torino? Current harness in torino is all chopped up
Edited by GranPeppers73 - 08-February-2019 at 5:34AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2019 at 11:57AM
94 CV has a 4.6, so distributorless ignition, fuel injection, computer controls power for lights, etc....
Not saying it couldn't be done, but major differences in the harnesses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2019 at 12:27PM
bird is right, lots will be different. welcome! btw
 what parts of your harness is hacked? there are 3 sections of the harness basically... under hood under dash, and tail light section
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 08-February-2019 at 3:12PM
Sounds like a major headache. I would find a donor harness/es set and go to it.
-John
72 GTS S Code
2015 Super Cab F-250
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 09-February-2019 at 2:52AM
you'll be choppin wires anyway----
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 10-February-2019 at 12:41PM
Welcome!  Like other's said like using a Crown Vic wiring harness is an idea that wouldn't save you any time.  I think you'd be better off to fix your original, find a used wiring harness, or find an aftermarket harness.
Unless you are planning on swapping over the 4.6L from the Crown Vic into the Torino.  Then I could see trying to adapt the Crown Vic engine harness.
